Old Sep 10, 2018 | 04:13 PM
  #6751
1stGEN'93's Avatar
Originally Posted by maybe368
The sight glass is on top of the filter dryer, it is tiny, but you can use it. It should be completely clear with R-12. The filter dryer is mounted to the passenger side fender...Mark P.S. It may be covered in crud...
Thanks. I’ll have to check that out when I get a drivetrain back in the truck.
Old Sep 11, 2018 | 01:24 AM
  #6752
Well our newest member Coffeeaddict had a break down today so I went out to help him. Turns out even before this we were PM-ing back and forth and it turns out we already knew each other..... So he gave me a call today when his truck would not turn over, I got there and they were using some very light duty jumpers and a 2nd Gen to try and boost it....just clicking at the starter, so hooked up my HD industrial jumpers the wires are like welding wire on those. After 15-20 min running Patches on high idle it would just barely roll over, so decided then to swap my battery into the his truck....fired right up! So now that we got it running the voltage gauge was only showing about 11.5 volts.....it's a 91 BTW. So tried a few things and could not get the charging to come up to the 13+ volts, so drove around town to find a voltage regulator, swapped that on and still not charging properly.
I did everything I could think of, cleaned grounds, and battery terminals and connections, added grounds, full fielded the alternator, hot wired the voltage regulator etc to make sure it was working, but nothing would bring the voltage up.....but I did not have my multi-meter with me so I was just going off the OEM gauge so perhaps it was wrong and it was charging. Anyway checked out his truck.....pretty neat unit and it is definitely a factory cab and chassis unit cummins/getrag and 3.54 rear diff, and is an original reg cab truck VIN's all match and there is no ext cab frame under it so must have been an error at the licensing dept. But it does have some sketchy wiring that needs to be repaired, cleaned up and/or removed.
Old Sep 12, 2018 | 11:11 AM
  #6753
Shelby/Dakota's Avatar
5 Year Member
Put the cap back on the truck in anticipation of this weekends camping trip/bachelor Party.
Also looks like I will be doing the rear axle seal again, appears to be leaking again.
Old Sep 12, 2018 | 11:17 AM
  #6754
ofelas's Avatar
Speedy Sleeve with National # 99287 if the seal surface is pitted.
Break it off at the scribed line and drive it in flush to the surface. Green loctite the seating surface first.
Reseal and done.
Old Sep 12, 2018 | 07:16 PM
  #6755
dodgenstein's Avatar
If this is a repetitive chore, have you checked your axle vent? They seem to get gunked up very quickly.
Old Sep 12, 2018 | 08:29 PM
  #6756
My thoughts exactly.
Old Sep 13, 2018 | 11:00 AM
  #6757
5 Year Member
Reseal and done.
When I did it last winter the mating surface looks to be pretty clean and free of burrs nicks or other surface defects.
Good call I'll definitely check that before tearing into the axle.
Old Sep 13, 2018 | 03:04 PM
  #6758
My rear axle is fine, it's my front axle that eats inner seals....it's a yearly swap the seals and clean and re-grease the front bearings. Having said that I need to order new seals and get this done.
Old Sep 14, 2018 | 02:58 PM
  #6759
FrustratedFirst's Avatar
5 Year Member
Repaired Odometer gears and Updated Guages
Thanks to whoever posted the sticky to replace the gears and to white face the gauges and paint the needles all fluorescent orange again! Also replaced all the guage backlighting with new LED's! I think it turned out awesome. Oh and **** retentive me was able to clean the 25+ years of nasty behind the dash bezel! Now for the new stereo and thumper speaker and amp stuff!
Old Sep 17, 2018 | 11:14 AM
  #6760
5 Year Member
So less what I did to it and more what I did with it. Went into the national forest over the weekend to do some shooting and forest road exploring. Ended up on a very rough "Jeep" Trail with the cummins, it was a very bouncy ride and new "pinstripes" were acquired. Truck did great despite being wider then the trail LOL.
Old Sep 17, 2018 | 11:20 AM
  #6761
mhuppertz's Avatar
Bought another receiver/dryer, evacuated the system but it wouldn't hold vacuum completely, just partially.
Finally gave up and put three cans of air duster in (R152a) and so far it has held.
Old Sep 17, 2018 | 11:21 AM
  #6762
mhuppertz's Avatar
Very nice! Which LED's did you go with?
Old Sep 17, 2018 | 02:50 PM
  #6763
5 Year Member
https://www.superbrightleds.com/more...rofit-car/206/
194 LED Bulb - 5 SMD LED Tower - Miniature Wedge Base
Part Number: 194-xHP5-CAR
I went with the natural light color
Old Sep 17, 2018 | 03:08 PM
  #6764
mhuppertz's Avatar
Thanks Much!
I want to eventually replace all the lights with LED's.
Old Sep 17, 2018 | 08:42 PM
  #6765
Very nice. Do they dim??
