Old Sep 2, 2021 | 04:01 AM
  #8251
KRB's Avatar
KRB
Originally Posted by Shelby/Dakota
well admitted defeat on actually getting hydroboost done in a timely fashion. Went ahead and got a new OEM master cylinder and replumbed the brakes. Now I just need to find a volunteer to help me bleed all the brakes. Then hopefully I can drive it for the first time in 2021.
My favorite volunteer to use is my friend Gravity, especially now that the kids are grown and gone, the dogs just don't seem to want to cooperate, they'd rather lay there and watch me struggle. If you have the time or other little jobs to do I like to crack the bleeders and let the brake fluid weep out on it's own. If the master was bench bleed good this works good enough to safely drive and sometimes I don't even have to use a vacuum bleeder or if I do, it's very very little and quick.
Old Sep 2, 2021 | 06:36 AM
  #8252
maybe368's Avatar
If you can’t find someone to help bleed the brakes you can always gravity bleed them. I successfully did that on my 90 even with the proportioning valve in the line… Mark
Old Sep 2, 2021 | 04:28 PM
  #8253
To bleed brakes by myself I use an old pop bottle with a hole drilled in the cap and a piece of old vacuum hose stuffed through, then a small vent hole in the top of the bottle. with the hose inside the bottle just below the level of some fresh brake fluid I then Loosen the bleeder, push the vacuum line on and then start the bleeding process,...slowly press the pedal down, and let it come back up slowly...usually takes me about 30 min to do a complete system.
Old Sep 2, 2021 | 10:20 PM
  #8254
edwinsmith's Avatar
Originally Posted by KRB
Yea, my torque wrench doesn't go that high but my metal cheater pipe with all my weight (200lbs) is set pretty close to that I think.
One might attach a come-a-long to the pipe and crank away until it pops.
Old Sep 7, 2021 | 12:45 PM
  #8255
FrustratedFirst's Avatar
5 Year Member
Old Oct 8, 2021 | 04:08 PM
  #8256
Back in the spring I went to put on new brake pads but one caliper piston wouldn't push all the way back in. Removed it and sprayed brake cleaner through and got out some junk out but even with a big C-clamp it would not go back in far enough to get it on the rotor with the new pads. I need the truck so just put it back together...fast forward 6 months and the squealers were starting to make some noise...guess I need to get some new calipers.
Order brand spanking new A/C Delco units and installed those the other day along with the wagner pads I tried installing in the spring. Man the truck stops so much better, you don't realize the slow deterioration over time. Also I hadn't realized one side was grabbing harder then the other....I just had adjusted my driving habits to compensate.
Old Oct 8, 2021 | 04:11 PM
  #8257
mhuppertz's Avatar
I need to do that. My truck slides left when I have to slam on the brakes.
Old Oct 8, 2021 | 05:45 PM
  #8258
u2slow's Avatar
Recycled my old/used '93 Injectors into my '90 because it'd become a fog machine. That fixed it.
It's too bad I left my new phone on the cowl when I went for the test drive. Not only did it slide off, but it went under the back tire. Guess I'm lucky I found it again, it still works... but with a badly cracked screen.
Old Oct 9, 2021 | 05:40 AM
  #8259
KRB's Avatar
KRB
Same here. I've had new calipers and rotors for about two years now, just no time to put them on yet... Looking forward to not every stop a panic stop!
Bummer on the phone u2slow. At least it wasn't something really important
Old Oct 10, 2021 | 07:46 PM
  #8260
BHD's Avatar
BHD
My Gear Vendors unit apparently had enough of hauling my pulling tractor around and managed to escape from my '90 W250 last night.
Old Oct 11, 2021 | 03:44 AM
  #8261
Wow that was a lot of torque to twist it off like that...probably been slowly working it's way towards this for a while I'd guess....Sucks big time!
Old Oct 11, 2021 | 05:08 AM
  #8262
KRB's Avatar
KRB
Dang! Does that unit have a rating or "capacity"? Bet that made a horrible noise...
Old Oct 11, 2021 | 05:54 AM
  #8263
BHD's Avatar
BHD
I'm sure it has, but it gave no warning except for about 30 seconds before it abandoned the ship.
It felt like I was on a huge rumble strip and it sounded like a big gear set that couldn't mesh at slow speed. I was off the throttle and in Neutral, which may have saved the rest of the driveline, but that's up for speculation.
GV rates them at 2000 hp and 25000lb gcvw.
Yeah, it rattled for a few seconds.....
Old Oct 11, 2021 | 06:27 AM
  #8264
Sorry to hear about and see the GV destruction BHD, that looks expensive.
Would the truck still limp down the road in 4x4 using the front driveshaft?
Old Oct 11, 2021 | 06:52 AM
  #8265
BHD's Avatar
BHD
Yeah, I was only about 10 miles from home and the trailer was empty, after I saw what happened I locked the hubs in and drove it home.
I'll be purchasing a metal detector today to try to find the little speedo transmission gear box that is made from unobtainium.
