Old Oct 1, 2018 | 11:32 AM
  #6781
Kansascrewcab76's Avatar
Finished the wiring on my RC, now I have power windows, locks and mirrors: also cut up hands. Lesson learned.....grease the tracks and rollers after assembly.
Old Oct 1, 2018 | 02:40 PM
  #6782
edwinsmith's Avatar
Eventually you'll come to regard your scars with fond remembrance.
Glad you have the harness wired up. Keep at it!
Edwin (Formerly of Coffeyville, KS)
Old Oct 2, 2018 | 12:43 PM
  #6783
Thanks for the positive vibes!!! I will never forget it, that is for sure.
Old Oct 4, 2018 | 08:40 AM
  #6784
mknittle's Avatar
Mine ate the HAVC blower motor resister! good thing it is cool out today!
Old Oct 7, 2018 | 02:29 AM
  #6785
1320Fastback's Avatar
Well Walmart dropped the ball on ordering my tires all at once instead of one at a time. After three weeks I immediately told them to cancel my order and I went to local tire shop and had two brand new Michelin Defender LTX Es put on today. This next Wednesday were towing our trailer to Henderson Nevada for a dog show and also the Monster Energy Cup and I didn't want to risk driving through the desert on old tires.
Old Oct 7, 2018 | 11:20 PM
  #6786
nothingbutdarts's Avatar
I put on a new master cylinder and both rear wheel cylinders, still need to put the pass. side axle back in, install my new to me fan shroud I got from Oliver along with the intake hose to turbo I bought as well, than maybe I can finally drive this big rig. LOL
Old Oct 8, 2018 | 04:57 AM
  #6787
KRB's Avatar
KRB
Just got back from a 400 mile round trip into the mountains. Left on Friday, right after reinstalling the starter with a LarryBs kit. Man that was more work that I thought it'd be! Averaged a little over 17mpg even on those grades and curvy roads.
Old Oct 8, 2018 | 09:06 AM
  #6788
1stGEN'93's Avatar
Saturday I installed a LPHV piston lift pump from The Hungry Diesel. It definitely has helped. My injection pump is on its last leg and was getting so I had to put water on it to get it cooled off to start the truck back up if the truck had ran within the last hour. It now starts every time. When I get back from my two years of religious service I’ll put a new THD injection pump in it.
Other than that the truck has been pretty good with the new transmission in. Only thing with it is I’ve found it doesn’t like to coast in 5th. It pops part way out if i coast it.
I also got my gauges installed and put the power screw in as far as it would let me go and backed pre-boost screw all the way out to flush. Truck didn’t even hit runaway and the screw only went in about 3 threads worth before it bottomed out. I took the slack between the pedal and the cable out and even with the pump turned up I can’t get it above 900 degrees, so I’m pretty happy. Only thing I need to resolve with tuning is figure out why it surges so bad at a certain rpm in each gear if I try to just cruise there. It does it about 22 miles an hour in 3rd and about 12 mph in 2nd. Haven’t had it do it in 4th yet, but I felt it start to one time about 37mph. I’m thinking that will be a starwheel adjustment as it seems it happens between low rpm and when the turbo starts to get some boost built up.
Old Oct 8, 2018 | 10:22 AM
  #6789
maybe368's Avatar
What did you do for the pilot bearing? My experience with popping out of gear is a bad pilot bearing...Mark
Old Oct 8, 2018 | 10:51 AM
  #6790
1stGEN'93's Avatar
It is a brand new flywheel that came with the Valair clutch kit. Throw out bearing is new from same source. It only pops out of 5th when I coast it. It doesn’t pop out of any other gear at all and 5th is fine if I am just driving and not coasting.
Old Oct 8, 2018 | 01:55 PM
  #6791
maybe368's Avatar
Cool, I assume that the new flywheel came with the pilot bearing or bushing already installed? Or was it in the Valair kit? The Dodge Cummins came with a pilot bushing installed in the flywheel, as opposed to the end of the crankshaft in many cars...Mark
Old Oct 8, 2018 | 02:10 PM
  #6792
1stGEN'93's Avatar
Yes. The pilot bearing was already installed in the flywheel.
Old Oct 8, 2018 | 09:26 PM
  #6793
edwinsmith's Avatar
I would take it back to the tranny rebuilder right quick and make them fix it!
Old Oct 8, 2018 | 09:35 PM
  #6794
Coffeeaddict's Avatar
How long ya figure? I'm trying to find the time but will likely wait for the snow to hit and other things to slow down..
Old Oct 8, 2018 | 09:59 PM
  #6795
1stGEN'93's Avatar
Problem is I don’t know who the transmission builder is. I bought it from someone who bought it from the builder and then figured out it wouldn’t go in their IDI ford. It is a nv4500, so I checked the 5th gear but and it hasn’t budged.
