Drag Wars
Old Sep 10, 2009 | 05:17 PM
  #241
morkable's Avatar
Yes I agree.. there is a short filter that he found to work on that, for the occasional "ice cream run"
Old Sep 10, 2009 | 07:21 PM
  #242
dvst8r's Avatar
This one is not the right size and they are a little ricey looking, but they work well and fit in tight areas.
Old Sep 10, 2009 | 07:50 PM
  #243
Mike Holmen's Avatar
The Guru
I have a dumb question, can anyone weld cast aluminum? You see the the two 90 deg elbows, they are welded to the turbo compressor housing. After that its easy. I think that you can tig, but I'm not sure. I'm sure we can score a 90 off the S595, but that 90 on the might be tricky on the inlet of the GT42. I have been doing some thinking about where to put the gates at.
I wonder if we really have to run an external oil filter. Might be tight, but its only a race truck that would get new oil once a season. That S595, looks massive, I'll find time next week to go thru the S500 housing line-up. I don't think that it will be that hard to do, but I still want to put on instruments to make sure you have the right turbos.
Ok, thats almost done , we should work on that fuel system and putting her on a diet and put on longer/stiffer traction bars. A 4 link would be nice upgrade. If we have 1200 HP, on fuel, we should at least put it into the track.
Old Sep 10, 2009 | 08:04 PM
  #244
dvst8r's Avatar
Yes I can weld cast aluminum. I have done it thousands of times.
Old Sep 10, 2009 | 08:08 PM
  #245
dvst8r's Avatar
As far as going down the track, it looks quite nice right now, other then the stock road going radials are not providing enough traction anymore, but if it is time to back halve and go 4 link then lets start drawing.
Old Sep 10, 2009 | 08:15 PM
  #246
dvst8r's Avatar
Kevin are you putting a fuel cell in it? Or staying with the stock tank?
Old Sep 10, 2009 | 11:38 PM
  #247
morkable's Avatar
fuel cell is sitting in my garage. Mike those traction bars I have worked like a champ,, actually allmost too long to be honest,, but I will fix my weight transfer problem this winter
Old Sep 11, 2009 | 10:06 AM
  #248
ccmckee's Avatar
I'm sorry to interrupt ,but does anyone else think that air filter looks like a boob
Old Sep 11, 2009 | 10:37 AM
  #249
morkable's Avatar
it may have a case of gangreen though
Old Sep 11, 2009 | 11:41 AM
  #250
bigd450's Avatar
When fabing the twins up I would also add in some brackets to hold the piping together.
Here is a picture of Tim Barber's setup using some brackets.
I know on my brother's truck the connection to the intercooler piping always blows off around 70-80psi. We need to fab up something to hold it together.
http://www.trediesel.com/pictures.htm
Old Sep 11, 2009 | 12:28 PM
  #251
The Guru
Just looking at those pictures, there are better hose clamps available. I get hose clamps that they use on air blower hoses. More surface area, and so more ablity to grab/hold onto stuff. Bends are the worst, as air will try to go straight. If you design the lines to stay as straight as possible, it will minumize tubes blowing off. Supports are always a good idea. If I was to build a 120psi twin system, there will be no hoses used at any of the joints. A pressure/seal fitting like used earlier set-up will take more abuse.
That air filter will just turn black in short order. I always want to run an air duct outside the engine compartment, to keep the blow-by/dirt/oil off that filter. Tim does a nice job on his twins
FYI- Also put a heat shield over the wiring harness, as the turbine housing on the secondary, tends to melt stuff. Been there done that.
Old Sep 11, 2009 | 12:55 PM
  #252
dvst8r's Avatar
As far as hoses blowing off we can just use v-bands like this setup uses.
Old Sep 11, 2009 | 01:02 PM
  #253
dvst8r's Avatar
Better yet are these Hargett clamps, as they allow for some movement, but are easier to use and quite a bit less money then an Adel Wiggins clamp.
http://www.hargettprecision.com/inde...8bfe1c5fecf02b
Old Sep 11, 2009 | 01:15 PM
  #254
morkable's Avatar
No 3.5 inch. Either 3 or 4. Might be an issue.. also they are still fairly pricy,, I like the vband clamp idea,, LOL
Old Sep 11, 2009 | 01:18 PM
  #255
Lil Dog's Avatar
Whoa! I like that setup.. Totally rigid. Reversing the HP turbo makes sense to me.
Those connections look good too, look similar to the stuff I see on Cats/Waukeshas.
