Drag Wars
Old Aug 21, 2009 | 11:30 AM
dvst8r's Avatar
Drag Wars
Good luck tonight Kev, I hope you get your 9.xx
Anyone else going?
Old Aug 21, 2009 | 12:08 PM
kennyblatz's Avatar
whatever happens keep us posted, good luck kevin
Old Aug 21, 2009 | 01:14 PM
Dr. Evil's Avatar
He said he will have video
Old Aug 21, 2009 | 01:40 PM
morkable's Avatar
Thanks guys,, Kelly is going to be running the video. I have tuned it down a bit, just so I dont break tonight,, I will probably dial it up sunday and see if there is a 9 in there.... also I will probably get kicked off the track if I run a 9.. between not having a proper roll cage, and no tranny blanket, and no competition license
Old Aug 21, 2009 | 02:08 PM
dvst8r's Avatar
Did you just dial back the spray? Or did you turn down your tune as well?
Old Aug 22, 2009 | 01:00 AM
morkable's Avatar
Just dialed back the nitrous.. got some runs in today,, lots of problems with fuel,,, running out before the 1/8 mile mark... the problem we were having last week is still there,, going to drill the tank and put a draw straw on in the morning.. sure was launching hard though,, spun the tires every pass, 1 run over 300 feet of rubber, before it ran out of fuel... should be some good stuff tomorrow if they prep the track better and I get the fuel issue figured out.
Ill keep you posted
Old Aug 22, 2009 | 07:36 PM
morkable's Avatar
Well my fass is definately dying. I removed the factory lift pump, and put a hose straight in for the fass, pressure still drops off,, got it maxed out, seems to hold at around 21 psi, maxed out.. have to replace that I guess.. Been launching really hard,, but I have been having alot of problems with the tranny going into limp mode on me,, havent really had a good run at all... actually have only ran 2 complete passes which were both really slow due to the fuel pressure problem... see what happens tomorrow I guess, have no idea what to dial in at,,
Old Aug 22, 2009 | 08:12 PM
Dr. Evil's Avatar
Thats too bad - hopefully you can get some warranty on that one. If not, it might be time to switch to an Airdog.
Old Aug 22, 2009 | 08:42 PM
morkable's Avatar
Yes it might be, going to try for warranty though and sell it then.. I will go to a bigger one then
Old Aug 23, 2009 | 12:18 PM
Swamp_Donkey's Avatar
Hope you get in a good run Kevin! Would a 47 rh help you out any or do you have to keep your 48re?
Old Aug 23, 2009 | 08:03 PM
dvst8r's Avatar
I have been away camping all weekend, just walked in the door. I'm glad to see the boots held, but sad to see that you have other issues.
Hopefully you got at least one decent run in this weekend.
Old Aug 23, 2009 | 11:03 PM
Doj Dewd's Avatar
you may want to look into a mitusa pump if you are going to be replacing the fass.
in talks with opie he has kits available for dual cp3's and the gusher pump (bigger one of two choices) will put out 200 psi if needed - of course this is controlled with a regulator.
Old Aug 24, 2009 | 12:02 AM
morkable's Avatar
Well as it turned out the fuel pump was the least of my worries this weekend.... I finally got all the other bugs out, and then I found a new way to screw things up,, lol. I put a sightline in my block, from either tire you can look through my engine and see the other tire. Amazing thing is, the truck was still making power for another 600 feet after this happened,, and even when I finally got the truck stopped it was still running, I had actually shut the truck off... lots of parts and oil all down the track...
I guess time for that dream engine,,, got any spare blocks in your garage there Mike,, LOL
Old Aug 24, 2009 | 12:33 AM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Wow....Thats not good..
Old Aug 24, 2009 | 01:13 AM
morkable's Avatar
No, not good,, know anyone with a engine for sale,, cheap,, lol
