Dealer added in tank to fleece power flow
Old Jul 27, 2024 | 07:48 PM
JRG's Avatar
JRG
I have an 03 with the dealer upgraded in tank pump. I'm trying to install the fleece power flow a d fleece wants to use the signal plug that the dealer upgrade is already using. I don't know where to make the power connections.
anyone have done this already?
Old Feb 20, 2025 | 05:39 AM
DallasFisher's Avatar
You may need a wiring adapter. Have you checked Fleece’s instructions?
Spoiler
Old Today | 03:10 PM
LucasWright's Avatar
Oui, ce problème arrive assez souvent quand on mélange différents systèmes de pompe de gavage. Dans ton cas, le kit Fleece n’a généralement pas besoin d’être branché sur le même signal que la pompe d’origine ou celle installée par le concessionnaire, c’est souvent là que les conflits commencent.
jmccart
15
May 24, 2007 04:25 PM
coontz0473
Oct 24, 2006 12:25 PM
Mike M
Jun 5, 2006 11:38 AM
Usta HaveA Hemi
May 4, 2006 02:41 PM
Nitecap
May 1, 2006 09:34 AM
