Drag Wars
I just mocked up a set of S366 and a S475, as in that first picture (S471/S510). That primary turbine housing would have to just about rub on the oil filter. I think that you could sneak the air tubing to the IC just over the exhaust manifold. It would be an really easy build. If you ran a S471/S480 twin combo, you could do the normal set-up, and keep the stacks. No need to hack-up the hood.
For twins, you want the secondary to be alittle smaller than what you would use for a single. Remember Kev, is using NOS (lots), so he really doesn't need a big primary as you would if you just ran fuel. I would run the twins set-up and see what it does. If a S488, isn't big enough, there is always bigger ones available.
The S510 primary, in a twin set-up would be perfect for a P pump motor that would push fuel until 6000 rpm. A big camshaft, fly cuts, 13mm pump, 7k gsk, ZZ intake (home made of course).
I don't like the 3rd gen block, it doesn't look as beefy as the 24VP or 12v blocks around the main skirting area. You can't put in a tappet plate gridle on a CR motor, theres no window there. Theres always something that you don't like.
It does have ribbing around the cylinders, which the 12v and 24v don't.
http://www.competitiondiesel.com/for...ad.php?t=59936
It does have ribbing around the cylinders, which the 12v and 24v don't.http://www.competitiondiesel.com/for...ad.php?t=59936
Tate, we need to build a S480 under that S366, for your dually. With a decent sized gate, I'm sure we could make some decent power.
Kev, your gonna have to take pics of the build for us small dollars guys can drool.
I will.. starting pulling the head off today,, between rain storms.... I really need a bigger garage. Anyways,, pulled the first 4 injectors and no damage,, WOO HOO,, I was worried about #4 and 3,, and they were perfect, so maybe the head never got touched...
