Drag Wars
Old Sep 9, 2009 | 07:29 PM
  #226
dvst8r's Avatar
Originally Posted by Tate
Isn't that a 510 on there? That was the setup I was referring to in one of my earlier posts, rediculously short hot pipe, and instead of having that long interstage pipe, you could run some sort of intercooler.
Same frame as the S510 just a 95mm vs 100mm compressor wheel, but according to the guy who owns the truck it is an S595 over an s471.
Old Sep 9, 2009 | 07:37 PM
  #227
dvst8r's Avatar
Originally Posted by morkable
That one there they have a ice to air IC in the cab. I would just turn that puppy around and pipe it into my IC and bobs your uncle,, push the exhaust through the hood and good to go
To me it looks like they are using an air to air, the manifold charger cold side inlet is facing the firewall, and the outlet is facing the fender under the down pipe just one 90 off the outlet and then it appears charge pipe goes under the atmospheric charger in a straight shot to the intercooler.
It has very short hotside plumbing, and looks to be fairly straight forward to replicate.
Old Sep 9, 2009 | 07:50 PM
  #228
Mike Holmen's Avatar
The Guru
Tate, I have to get my head around the too cold for combustion theory? I don't think out loud here (and can be totally wrong) that the air is gonna be toasty (guessing 500 to 600 deg's F) that at 100 psi of boost. I'm guessing that you'll be 200 to 300 deg's when when you spray, prior to going into IC.
You could use a smaller air/air intercooler. We have to do some testing to determine the amount of NOS and location of where to spray. The trick is to get tons of air into the cylinder to burn all that fuel. The most efficency way makes the most HP. We just have to figure how to do it. I'm game to try stuff. The thermocouples are pretty cheap, the pressure devices aren't cheap but aren't real pricey. I have to figure out a cheap way to measure each turbo rotating speed. A few lite throttle burns around town on the way for ice cream would work.
Old Sep 9, 2009 | 09:32 PM
  #229
1-5-3-6-2-4's Avatar
Ill see if I can get turbo speed sensors individually from work. I know the DDEC V engines use it on the turbos.
Old Sep 9, 2009 | 09:46 PM
  #230
morkable's Avatar
Ill have the new engine sometime in October. I will try to have a few of the other things done, and maybe I can come down for a couple days so we can work on these turbos there,,, have to see how it all works out for everyone
Old Sep 9, 2009 | 10:26 PM
  #231
dvst8r's Avatar
I have a turbo speed sensor from this Holset HE351ve. Not sure if it is easily adaptable though.
Old Sep 10, 2009 | 11:45 AM
  #232
bigd450's Avatar
Here is a few pics of guys that have some pretty darn big turbo's.
http://www.competitiondiesel.com/for...152#post587152
http://www.competitiondiesel.com/for...ad.php?t=46213
Here it is in the Diesel Power mag.
http://www.dieselpowermag.com/featur...500/index.html
I also believe Rob is running a 71 over a S500.
https://www.dieseltruckresource.com/...5-t243503.html
Old Sep 10, 2009 | 12:13 PM
  #233
The Guru
Nice set-up, The first twin set-up will be fun to build air line into the intercooler. It can be done, but its gonna be painfull. There a shock tower right between the secondary and primary turbo. I didn't see any external gates on either set-up, so it makes to look pretty clean. The secert to get the primary to spool-up fully, you need to bypass the secondary turbo as at some point it will hinder top end power. A set of twin 50mm external gates would make the build more complex. We can try a set with no gates and one with gates, its just time.
I have a front half clip, so we can do some complete mock-ups, so its just bolt in.
Old Sep 10, 2009 | 12:34 PM
  #234
dvst8r's Avatar
I really like having the manifold charger low mount, and the atmospheric charger top mount. Better look and easier to do in my opinion. However from a weight stand point it is probably better to do it the other way around, keeping the weight as low as possible.
Old Sep 10, 2009 | 12:38 PM
  #235
morkable's Avatar
I like the idea of the 1st one... man that is a big turbo though,, LOL I really think though that we are going to need the wastegates for sure though...
Old Sep 10, 2009 | 01:17 PM
  #236
The Guru
I'm guessing that the first twins set-up is using a S400 series turbo, sure looks like one anyways. I didn't see a internal gate or any external gates. The air IC tubing would be easier if the primary would sit down lower near the frame, but I bet then you'll have exhaust issues. I have a front frame clip off an 01 truck. So you can see how everything fits together. I'll take the picture down to the shop and spec out the turbos that where used. I would like to use a smaller turbine housing than that big primary, if possible. I think that its a S595 for a waukesha, for a 43L motor
Old Sep 10, 2009 | 01:21 PM
  #237
morkable's Avatar
Dont forget Mike that I want to run a hood stack, that should make things a bit easier
Old Sep 10, 2009 | 02:09 PM
  #238
dvst8r's Avatar
From a fab stand point this one that looks to be the most straight forward package:
Old Sep 10, 2009 | 04:30 PM
  #239
Tate's Avatar
That setup is the most simplistic from a fab stand point. Only issue would be room for the air filter, since the turbo is so far forward. But as long as a hood is being run, he's not required a filter.
Old Sep 10, 2009 | 05:02 PM
  #240
dvst8r's Avatar
At the track I would just run a screen over the inlet, and pull the headlight.
