newbie here
newbie here
just bought my first cummins after owning powerstrokes and a duramax. like it so far but having issues with the tire pressure monitor, it wont go off even with the correct tire pressure have driven it for over 40 miles and still wont reset itself. anyone else run across this?
Thats MR Hoss to you buddy!
Just double check the numbers on your door for light and heavy load and adjust accordingly. Hopefully that solves your problem.
That sounds right. As long as you're above the psi on the door it shouldn't be giving you a low pressure warning. If driving around doesn't reset it then you make have to take it in and let the dealer look at it.
SSminnow
04-09-2004 07:52 AM
Idaho Guy
22
03-06-2004 12:33 PM
mkiv_tt
16
09-17-2003 01:00 PM
