4th Gen Engine and Drivetrain-2010 and Up 6.7 liter Engine and Drivetrain discussion only. PLEASE, NO HIGH PERFORMANCE DISCUSSION!
difficult to engage 2nd and reverse. clutch?
Old Mar 30, 2013 | 12:39 PM
rootercycles's Avatar
All,
My 2010 3500 4x4 6 speed manual has about 6,000 miles on it. It is very difficult to get into 2nd or reverse. Is there a way to adjust these hydraulic clutches?
Old Apr 1, 2013 | 01:15 PM
SOhappy's Avatar
What does the dealer say? You're still under warranty by a long ways. Only 3,000/miles per year?? Maybe it's just stiff from lack of use
Old Apr 1, 2013 | 03:14 PM
ColinP's Avatar
Will it easily engage those gears with the engine switched off?
Old Apr 1, 2013 | 05:37 PM
Grit Dog's Avatar
Where do you live?
Meaning is it cold out?
My G56 is a little stiff going into gear or shifting if left outside at 30deg or below until it's run down the street for a mile or so.
6000m isn't even near being broke in, at all.
There's some threads about the G56 that reccomend different fluids etc to ease cold shifting plus filling it a quart over full.
I've changed my trans fluid the last 2 times using synthetic ATF to full and then an extra qt of Lucas trans oil/fix. Was reccomended by a hot shotter on here and I noticed it was easier to shift it cold than before.
If it's difficult all the time, then I dunno. Have had no problems with mine in over 100k miles.
Old Apr 1, 2013 | 06:36 PM
Busboy's Avatar
There was a TSB for the G56 jumping out of reverse and in that TSB it mentions to be careful with second gear and not to do something?? while replacing the reverse gear synchro, I forget but the two are connected. Go see the dealer.
RDMueller
Dec 30, 2008 11:15 PM
BigDodgeBigHart
Apr 13, 2007 10:26 AM
BigDodgeBigHart
Apr 13, 2007 09:18 AM
More Power
Feb 3, 2004 06:01 PM
