need bullydog help ASAP!!!!
ok so i started my truck tonight 2007 5.9l cummins with the bullydog pmt installed. the pmt flashed a couple times than finally loaded. i thought something was fishy so i looked in the system settings. it has all of the right vehicle information but when it shows software setting its for an 06-07 6.6l duramax. what do i do? do i load back to stock what please help!!!
I had a problem with my outlook monitor. The monitor would not hold its memory so it would sometimes default to the first setting on the list which was a Ford. When that happened the truck would not run and I could not remove the program. The only resolution I could get was calling BullyDog and they walked me through it. The problem it had was it said there was a VIN mismatch and it locked the downloader. If it runs it might be a good idea to wait until you can reach BullyDog tech support before you try to change anything. Not sure if the PMT would do the same thing but if it does it might dissable the truck.
By the way the resolution with mine was they replaced the monitor with a new one and no more problems with the truck thinking it is a Ford.
LilBigd02
17
02-28-2010 09:22 AM
horselady
01-27-2009 12:01 AM
stock03
09-30-2008 09:03 PM
bigsilver
25
10-03-2007 09:30 PM
