Old Oct 5, 2015 | 01:16 PM
  #1411
I also run a small clear pre-lift pump canister type filter. Keep a spare one of those in the glove box as well. I like the clear ones because you can see the crud coming out of the tank.
Old Oct 5, 2015 | 01:19 PM
  #1412
Nothing going on with the crewcab recently, but I just finished burning through my 3rd tank of fuel since installing the 14cm hot sided turbo. I am averaging 20.5mpg per tank now, so up about 0.5-1.0mpg over the original 18.5cm unit.
So pretty happy with that! Might try turning the fuel screw in 1 turn and see how that effects things.
Old Oct 5, 2015 | 07:25 PM
  #1413
Can you elaborate on this ?
You cut the plastic fuel lines ?
How do you get them to seal ?
What brand of filter do you use ?
Por Favor ? Amigo....
Old Oct 5, 2015 | 09:28 PM
  #1414
Just a basic Fram 5/16 filter. And yes I cut the plastic line, but had to anyway due to the longer wheel base of the crewcab, compared to the club cab. I bought a pack of fuel injection line hose clamps, they seal more evenly around the whole line.
One day I will install new line form the tank sender, to the lift pump, but for now the plastic line is working.
Old Oct 6, 2015 | 11:58 AM
  #1415
ofelas's Avatar
Prepped & glued a factory bumper cover on to the rear bumper...I used spray 3M #20 - surprisingly strong & rock solid...was pretty immovable about 30 minutes after application.
Old Oct 6, 2015 | 01:18 PM
  #1416
bigragu's Avatar
. Wish I got 20 mpg for as much driving as I do. Mine has gotten a little better since the install of the DAP 5x12's. Was averaging around 14.56 with those POD's, now I'm at 16.89. Hopefully, with more of a tender foot and less of Bay Area stop and go and stop traffic, my mileage will increase s'more. Don't see the Bay Area traffic changing, though....
Old Oct 6, 2015 | 02:04 PM
  #1417
You just cut the original locking nubs off then? What bumper did you glue it too, a standard checker plated top chrome bumper?
Old Oct 6, 2015 | 02:34 PM
  #1418
ofelas's Avatar
That's exactly it.
Btw - I saw mileage improvements when I went to the 14cm turbo housing as well; I have it wastegated at 25psi. The fuel screw is turned in 2.5 turns, and it's just the skinny pedal that er affects mileage now ;-)
Old Oct 6, 2015 | 03:11 PM
  #1419
j.fonder's Avatar
ya, off of a perfectly good pad that he stole from my garage
that's why we can't have nice things!
Old Oct 6, 2015 | 04:18 PM
  #1420
ofelas's Avatar
Lol. I think you offered it up after the third beer. Free beer + a free pad - a good day.
Old Oct 6, 2015 | 05:12 PM
  #1421
I figured you got it from Justin....I remembered him pulling the pad from one of the spare rear bumpers he had.
What does that say about us when you can remember other peoples parts inventory...
Old Oct 6, 2015 | 05:13 PM
  #1422
ofelas's Avatar
Hah! True enough! How"s the truck running? What plans for the winter mods ?
Old Oct 6, 2015 | 06:07 PM
  #1423
d9inger's Avatar
The 93' W250 won't start. Battery is fully charged, reading 12.6V or so, I can jump the starter with a pair of pliers and it runs (with the key on), battery voltage reads 13.9V running.
Pulled the connector for the relay, put battery voltage to the red (I think it was red) on the relay plug and it started. Ignition still on.
shut down
Checked the yellow wire (still unplugged from the relay) with the key in run, zero V, turned the key intermittent to start and I get 8.5-9V
I'm guessing that relay will not work with 9V...
All fuses are OK,
I'm only getting ~9V to the yellow wire at my relay.
Suggestions?
bad relay?
Bad ignition switch? (wipers work with it on run)
Oh yeah
I put a T-pin in the relay connector on the yellow wire, plugged the relay back in and put battery voltage to the yellow wire side of the relay and it started.
unless I have a weak relay, I have a voltage loss somewhere between my ignition switch and the starter relay.... in my opinion.
any ideas?
Old Oct 6, 2015 | 07:22 PM
  #1424
I have a OEM bumper top pad if anyone wants it. Keep kickiing it around in my garage, and I'm sick of stubbing my wittle toe...
Free to anyone willing to pick it up.
Old Oct 6, 2015 | 07:42 PM
  #1425
j.fonder's Avatar
haha, I had 2 spares, of course ol' Chip took the best one! told him you couldn't have a front step pad bumper and not the rear. glad I could contribute to the flying pistachio!
oh and btw, i've looked through your random parts classified ad probably a dozen times looking for something i "need". i guess you're holding onto all the good stuff! but do you know how many times i've thought to myself "hey, i think i saw one of those in the classifieds!" when I or someone else needed something
kind of where I was at, have spare front and rear step pads. i know the moment i give them away i'll rear end/back into something and won't be able to find another one to save my life.
i'd need a 3 car garage to be comfortable with how much stuff i have crammed into a single...
