From what I gather, it can be used as Mark used it to "accentuate" the word, making it more "pro-nounced" or to "Stand-out", (rule 2a) as it's allowed, even though Mark used it following a noun, vs before the noun "one" in question.
For example:
"and should be studied, lest it appears as the un-educated one"
vs Marks version:
"and should be studied lest one appears un-educated."
Man, it's been a long time since I've looked up how to use a hyphen.
Makes me feel much older than I really am. This is what drinking and playing on the internet will do to you (me)....
Oh yeah, Friday night drinking can be so fun, and at the same time, show you how you're not the same fella you were, some 30 years ago, drinking in a bar, and getting into fights.
https://www.grammarbook.com/punctuation/hyphens.asp
For example:
vs Marks version:
Oh yeah, Friday night drinking can be so fun, and at the same time, show you how you're not the same fella you were, some 30 years ago, drinking in a bar, and getting into fights.https://www.grammarbook.com/punctuation/hyphens.asp
Yesterday I went and got a rear output seal for the np205 and will see if the weather allows to do it tomorrow. We’re supposed to get quite a snow storm here so we’ll see. I wish I had a space to pull the truck into, but all I have is a concrete slab.
Today I compiled a list of things to do to it. not sure I’ll ever get it all done, but we’ll see! I want to mount a 5 speed back in the truck ASAP! It just was not meant for an auto and the 47rh wasn’t done the most proper way either. Seems I top out about 75 on a gps if I’m lucky. That’s with the torque converter locked too. Truck doesn’t seem like it is revving out, just like it doesn’t have the power to go any faster.
I need to get gauges soon so I can try tuning the pump a little. I plan to get it to where it either runs too hot and then turn it down some or just smokes too much. I don’t like having smoke rolling out my tailpipe or blacking our roadways. It’s not good for the truck and just makes people mad. I just want to be able to get up to 65 without giving heavy throttle input and in less than a mile as well. Here again I have another never-ending list!
Did you upgrade the pump to the 366 spring? No ?
That would explain the inability to go faster.
1stGEN'93,
If you can only go 75MPH, even without the 366 spring, you must have 4.10 gearing, or the O/D is not working on that 47 RH.
The OD gearing on the 47 RH is really close to the O/D gearing on the Getrag, so that will not fix the problem you seem to have with your MPH search.
Have you checked that you are actually getting full throttle movement from the pedal to the injection pump?..as in are the cable and / or throttle linkage not adjusted right and you are not getting all you should be?
According to the tag on the axles I have 3.54 gears. I don’t have a aftermarket spring. Overdrive kicks in VERY notably and it takes some time to build boost back up even with foot to the floor. I had a friend watch to see if the throttle hit the throttle stop and it didn’t quite touch it with pedal on the floor. Some days it will do 70 no problem, but others it struggles to do 70 and seems to never build boost for the longest time. I get even more frustrated with the 47rh being my o.d. is on one switch and my torque converter is on another. I’d rather push an extra pedal and have full control.
It will wake that engine up like no other..
So it will give me more power across the board or it will just make the truck rev higher? I don’t want to be running 3k for a few hundred miles when the time comes to take it on the freeway. Then again, I don’t want to get passed by semis.
So then your speed issue has nothing to do with your 47RH and is somewhere between an improperly working throttle linkage and likely a factor specced injection pump.
For a comparison my 93 with a 4.10 ratio will do about 85-90 mph. That as fast as one really needs to go while actually using a truck for towing.
If you have the OD working and 3.54 gears and can only do 70-75 MPH you have some other issue.
My '91.0 or RC with 3.54 gears and an working [Getrag] O/D has no problem doing more than that in 4th gear let alone in O/D.
It does not sound like a gearing issue to me, unless I am getting wrong info on the O/D working or axle ratio.
How is the fuel delivery system? Still full of greasy left overs?
What sort of boost #s are you talking?
You won't believe the difference.
I don’t have gauges yet so I don’t know what boost I’m running. I know I have had some people complain about how loud the turbo is in the passenger seat, but that probably doesn’t mean anything. Not sure if it is still full of grease or not. Truck hasn’t given me any issues other than the transfer case leaking for a while now. It cleared up pretty quick and all the left over particulate seemed to get filtered out after a couple filters. I will have to look into that spring after I get gauges here soon. I’m thinking I’ll go with glowshifts because a guy on the fire department with me says he has a family member that sells them and they put a lifetime warranty on them. Seems reasonable. I’m thinking I’ll get the glowshift 3 pillar pod with trans temp, pyro, and either boost or fuel pressure. Kinda sounds like I’d be best off getting the boost and just getting a cheep fuel pressure gauge that is under the hood like a couple I’ve seen. That way I could just see what my pump was running and investigate either a filter change or lift pump. I also plan to get a HVLP piston lift pump. I figure gauges should come first though.
I don’t have gauges yet so I don’t know what boots I’m running. I know I have had some people complain about how loud the turbo is in the passenger seat, but that probably doesn’t mean anything. Not sure if it is still full of grease or not. Truck hasn’t given me any issues other than the transfer case leaking for a while now. It cleared up pretty quick and all the left over particulate seemed to get filtered out after a couple filters. I will have to look into that spring after I get gauges here soon. I’m thinking I’ll go with glowshifts because a guy on the fire department with me says he has a family member that sells them and they put a lifetime warranty on them. Seems reasonable. I’m thinking I’ll get the glowshift 3 pillar pod with trans temp, pyro, and either boost or fuel pressure. Kinda sounds like I’d be best off getting the boost and just getting a cheep fuel pressure gauge that is under the hood like a couple I’ve seen. That way I could just see what my pump was running and investigate either a filter change or lift pump. I also plan to get a HVLP piston lift pump. I figure gauges should come first though.
Mine runs better all the way from idle up. after the 366 spring install.
Now that you, I and Oliver told him to install the 366 spring, he will
Exhaust temp, fuel pressure, and boost are available from glowshift, in a 3 in 1 unit . I have it in my steering column, and it helps understand what's going on while I drive.
