#6841
Edwin, I'm thinking your truck was mad at you for putting that K&N filter in it and was trying to run away from home
On the good side at least there was no major damage
#6842
Today I filled the windshield washer reservoir with blue stuff and tried it out and it works fine now.
I just added the scratch to the list of paint dings I have to fix someday.
nonrev (11-17-2018)
#6843
Received 1,637 Likes
I finally bought a K&N air filter for my rig. Installed it a few minutes ago. This is after I parked the truck in the garage with out leaving it in gear or the brake applied. Well I leaned against the truck and it rolled out of the garage onto the sloped part of the drive way and I couldn't stop it! I rolled all the way down to the street picking up speed as it went. It rolled across the street and hit the curb on the other side and kept going. Luckily it didn't damage anything when it hit the wall. The hood was open so it put a nice big scratch in it when it hit the door opener. Luckily there was nobody else coming down the street to witness this bit of stupidity. I didn't see anyone else so I jumped in the truck and drove it back into the garage like nothing happened.
My windshield washer tank had some crap on it like a thousand cobwebs so I took it off and cleaned it all up. Te plastic screen had a hole in it so I pit some shoe-goo on it to plug the hole and I'm waiting for it to dry.
Lots of FUN today!
Edwin
Lots of FUN today!
Edwin
What is this wall you're talking about? A neighbors yard?
#6844
I checked and the shorts are fine. The wall is a concrete block dividing the neighbors back yard across the street from the sidewalk. The curb slowed the truck down enough that it just hit the wall with a good thump but didn't do anything other than leave some rattle can black paint on it. It gets tagged often so graffiti abatement will paint over the whole thing soon enough. The back bumper is made of 6" channel steel and reinforced at the ends so it's pretty much indestructible.
#6846
Noticed a coolant leak by my oil filter a few weeks ago, haven't been able to pin point it. Today I noticed it's drippng even more. Looks like it's around the Tstat. I don't think it's the HG because the lower 1/4 of the housing is wet and the lower bolt as a dropplet on it. I am really hoping that its just the Tstat anyway timing is really bad for a HG.
nonrev (11-21-2018)
#6847
I pulled everything apart, checked the oil cooler, cleaned everything up, new gasket, new T-stat, filled it up with straight antifreeze with no water added and re-installed it last winter and it has been good to go since.
While I was there I installed a HX-35 turbo, 2nd gen intercooler, boots, tubes and a '94-'98.0 intake horn, but that is another story....
peckens (11-21-2018)
#6849
I dried and cleaned everything off yesterday. So far the HG is dry its just the lower bolt on the Tstat housing that is wet. Will double check the oil cooler just to be safe.
#6850
Today, I drove the truck for the first time since I got it back from the transmission shop.
Took the extra 1.5 pints out of the trans, as they had overfilled it.
Adjusted the TV cable, which they NEVER DID.
Truck shifts just about perfectly now.
Sure felt good to get it back home.
The following 5 users liked this post by NJTman:
edwinsmith (11-26-2018),
maybe368 (11-21-2018),
N. Besonderes (11-22-2018),
nonrev (11-22-2018),
oliver foster (11-21-2018)
#6851
Checked the coolant leak again today as the truck has been sitting for 24 hours. Tstat housing is more wet than it was before, about half way up the front side actually (way above hg). Guess tomorrow after work I will pull the tstat clean the mating surfaces and rtv it.
#6852
I was sure that the front input seal on my NV4500 was what was leaking oil like a sieve. But when I rolled the creeper under there to loosen the first of many bolts, after purchasing everything I needed and making plans to take time off in order to pull my 4X4 drive-train, I noticed that it was just leaking from the PTO cover. Fixed in an hour.
I'm still going to pull the drive-train soon so that I can give her a new rear main seal, reseal the NV4500 and NP205, and twin-stick it but, I like to do that kind of stuff on my own time, not in a pinch.
-Niemand
The following 2 users liked this post by N. Besonderes:
NJTman (11-23-2018),
thrashingcows (11-22-2018)
#6854
Twin swirl
Looks similar to the twins swirl combustion recirculation exhaust system I just installed on my old sled from EMBS , remove 4 inch exhaust improve mileage 4.72 per gallon ...ofelas always cutting edge... aircraft approved
ofelas (11-23-2018)
#6855
I let it think about it for a few days and discovered it wasn't leaking - Dooh!!! - it was just the PB Blaster I had sprayed on the brake fitting to replace the hose at the wheel!
What a relief!!!
thrashingcows (11-24-2018)
