Old May 4, 2016 | 02:58 PM
  #2521
1320Fastback's Avatar
Defiantly will be a mod soon. Not sure why the seal popped out with stock lift pump and being new.. Just one of those things I guess.
Old May 4, 2016 | 07:16 PM
  #2522
Originally Posted by jtamulonis
if the front seal is out, put it back in and get a big flat washer that`s the same out side diameter as the seal boss on the pump. drill 2 holes in the washer, and drill and tap holes (#8 or #10) in the seal boss to match the washer. bolt the washer to the boss with lock washers and blue loc-tite. just be sure to NOT drill all the way through the boss. there`s plenty of metal to drill 1/4 or 5/16 deep. then the seal will NEVER pop out again. there`s plenty of room behind the pump gear for the bolt heads and washer. I have done this to both of my VE pumps, for my piece of mind, when I put on piston lift pumps with 18 LB. springs in them.
That's STICKY WORTHY....
You need to do a write up on that with pix..... Otherwise, I'm sending Papecat over to your house to light up a paper bag of dog doo on your front porch.....
Lord knows how much he loves to light crap on fire......
Old May 5, 2016 | 08:14 AM
  #2523
boeingguy's Avatar
mod
Originally Posted by peckens
Did the door reinforcement mod today. Thanks to the inventor, doors are much more solid and no longer flex.
did you cut the door to weld that in flush, or does it sit on top of door, hard to tell
Old May 5, 2016 | 08:38 AM
  #2524
mknittle's Avatar
Glad you brought this back. I would like to do this mod also.
Old May 5, 2016 | 08:45 AM
  #2525
boeingguy's Avatar
I have the cab gutted, should be perfect time, just can't quite tell from pics what to do .
Old May 5, 2016 | 12:29 PM
  #2526
mknittle's Avatar
I saw some pictures and a short write up of how a guy cut the doors but I can't find it. it was in a build thread I think.
Seems like he used 3/4" thin wall tube. I know there was some cutting but I don't remember just how much.
A straight edge and a good ruler would tell.
Old May 5, 2016 | 12:39 PM
  #2527
boeingguy's Avatar
if i cut it so its near flush, then it should not interfere with door panel i would think.
Old May 5, 2016 | 03:39 PM
  #2528
mknittle's Avatar
Yeah, I think so too. as long as everything inside clears and it is flush with he front to rear surfaces of the door you should be golden.
Old May 5, 2016 | 08:05 PM
  #2529
His name was "wheelieking".
and yes, I did the mod when he posted it originally. He was a decent fella, but didn't like being goofed on. Thin skin, took it personally and never saw him again (or should I say read him again). Been a few like that here.....but then life goes on...
Great mod.
Flush with the door panel. I used 1/2" square tube, and it worked great. makes a HUGE difference in the feel of the door. Worth the time to do...
Old May 5, 2016 | 08:07 PM
  #2530
Either look up wheelieking or spend way too much time looking through my old threads...
Either way, it's in here somewhere.
Old May 5, 2016 | 08:26 PM
  #2531
mknittle's Avatar
thanks T man.
Old May 5, 2016 | 08:31 PM
  #2532
mknittle's Avatar
Here ya go.
https://www.dieseltruckresource.com/...ieking-302803/
Here shows the cut.(toward the bottom of the page)
https://www.dieseltruckresource.com/...-301470/page5/
Old May 6, 2016 | 07:28 AM
  #2533
boeingguy's Avatar
thanks guys!!!
Old May 6, 2016 | 07:35 AM
  #2534
That guy. Was brilliant in some of theworkhe did. Too bad he didn't have the ability to take any criticism about anything or field off ( all in jest ) goofy jokes at his expense. I guess brilliance and bunched up pink panties make for a toxic combination.
Lol
Old May 6, 2016 | 08:12 AM
  #2535
Same "dude" as the guy I bought the Guantlet from out in AZ.
Looks like he just changed his "name" after being Banned as "Wheelieboy"
