Old May 7, 2016 | 04:29 PM
  #2551
1320Fastback's Avatar
Originally Posted by NJTman
One of youus guys have a $3.5 million cuda sitting in your garage?
I wish I did
http://http://autoweek.com/article/c...ngs-35-million
I know I don't but a guy did stop by today and offer me $15K for my old fastback... Kinda wish I didn't tell him no
Old May 7, 2016 | 04:36 PM
  #2552
So today after finding out my lift pump wasn't the cause of having 7.5 gallons of dieselW40 in the crankcase I pulled the injection pump out. I had just resealed it last month so the procedure and tools were still fresh in my mind and got it out in a hour or two.
The seal was defiantly popped, once the Key was removed it fell off the shaft.
I am a bit confused and concerned that it popped out only having a stock lift pump.
The seal kit was a Ebay one but this seal say Flag Germany and has the same dimensions printed on it as the genuine Bosch seal I got Friday at a Bosch rebuilder.
Before I lock tight this one in and think I'll also stake it with a punch not unlike how some fix the KDP I will change out the return fuel lines and make sure the screen is clean in the return fuel banjo bolt. Not sure if that could increase internal pump pressure but something made this seal pop with about 1,000 miles on it.
Old May 7, 2016 | 06:46 PM
  #2553
jimbo486's Avatar
Originally Posted by j.fonder
I guess it's time to experiment in the powder coating game!
Dependent upon if the color can be matched and what it would cost to coat it.
Originally Posted by MrFusion
^^^^X2 on powder coating.
Is the AFC top aluminum? I've never had much luck getting primer and paint to stick to aluminum well. I've bead blasted small aluminum parts and it hasn't made much difference.
Did you prime the ATS manifold prior to painting? I primed and painted my ATS manifold then cooked it through the 3 cycles on my gas grill using a touchless thermometer aimed through an opening in the side of the grill hood. I got to around 550 on the last stage and left it in for 45 mins.
The AFC top is aluminum. I've read elsewhere that a self-etching primer might help. But what I noticed was that the primer and base coats seemed to adhere just fine. It was the primer that didn't adhere to the aluminum. What you see in the picture is the bare, bead blasted aluminum. I could try a good scuff with some sandpaper next time.
I did prime the manifold prior to the base coat. Used VHT's Flame Proof primer and flat black. Being a cast, ductile iron, I'd like to think the paint will adhere well to it.
Originally Posted by mknittle
Jim, you are having way too much fun. Be careful not to get an overdose.
An overdose of fun can get ugly.
I certainly am having fun. I'm not aware of any 12-step program for this kind of addiction but regardless, I don't think there's a cure for it. I'm eager to get this thing back on the road!
Old May 7, 2016 | 06:58 PM
  #2554
j.fonder's Avatar
Eastwood and prismatic carry hemi orange powder.
Old May 7, 2016 | 07:35 PM
  #2555
jimbo486's Avatar
Thank you very much! Found an applicator for Prismatic not too far from me. I'll call for a quote to have all of the other parts redone as well.
Old May 11, 2016 | 12:58 AM
  #2556
Put the injection pump back in, again.
Fired right up without a studder after bleeding lines and filter.
Hope seal stays put now for good. Have a 700 mile trip to pick up a flatbed car trailer and some farm equipment weekend after next.
Old May 14, 2016 | 01:01 AM
  #2557
jimbo486's Avatar
I haven't gotten much more done. Lately, I've been spending time painting miscellaneous parts that I bead blasted. I ordered the stainless braided hose for the coolant bypass. I should be seeing it someday next week.
Installed the transmission adapter and flywheel minus clutch assembly.
Water pump and fan hub bracket.
Old May 15, 2016 | 03:09 PM
  #2558
Looking good Jim! What's up with the brass? spacer on your fan hub?
Old May 15, 2016 | 03:14 PM
  #2559
Last couple days just did a few small things. Replaced the O-ring on my high pressure line off the PS pump...slowed the drip, but did not stop it.
Yesterday I turned in the fuel screw one full turn. Found that the lock nut on the fuel screw was not even tight...not sure if I forgot to tighten it when i rebuilt the IP 2 years ago, or if it rattled loose? Had to adjust the idle back down after turning in the fuel screw. Took it for a drive and it definitely has a bit more jam! I'm not hating it that's for sure.
Had a couple lights out as well....so replaced those, then gave Patches a good wash.
Old May 15, 2016 | 03:35 PM
  #2560
jimbo486's Avatar
Patched up and filled some holes yesterday. I changed my mind about OEM cab lights and decided to use 3rd gen cab lights for a lower profile look.
Did away with the still existing, Getrag shifter hole. I had some body panels that I had already cut into pieces. I made a template on the aluminum sheet that was initially covering the opening, cut it to shape and traced it onto a body panel and cut that out to use as the filler. I also filled the remaining holes used to fasten the shifter boot and the previous aluminum patch panel as indicated by the red markings. I bought an 11lbs spool of .023" wire but goofed and didn't get the proper drive rolls for the Hobart. I managed to make .030" work just fine.
Still have some clean-up to do inside the cab.
Old May 15, 2016 | 03:42 PM
  #2561
jimbo486's Avatar
It's a spacer to replace the 2 big washers I was using to clearance the fan for the Fluidampr. I took dimensions of the shank (ID), shelf (OD) that the fan clutch nut seats against and the overall thickness of the 2 washers I had, gave them to a machinist friend and asked him to make me a spacer out of something. That's what I got back. Can't tell if it's brass or bronze though. Not quite as orange as brass is. More yellow-ish. I may end up buying a fan clutch for the later engines for the hell of it. If I do, I'll see if he can turn the spacer down some to expose more threads on the shank.
Old May 15, 2016 | 04:47 PM
  #2562
Originally Posted by jimbo486
It's a spacer to replace the 2 big washers I was using to clearance the fan for the Fluidampr. I took dimensions of the shank (ID), shelf (OD) that the fan clutch nut seats against and the overall thickness of the 2 washers I had, gave them to a machinist friend and asked him to make me a spacer out of something. That's what I got back. Can't tell if it's brass or bronze though. No quite as orange as brass is. More yellow-ish. I may end up buying a fan clutch for the later engines for the hell of it. If I do, I'll see if he can turn the spacer down some to expose more threads on the shank.
Thought that was what it was for.
Old May 17, 2016 | 12:12 PM
  #2563
jimbo486's Avatar
Just need to determine which of the later fan clutches would be the more gooder one.
I saw your mentioning of the Hayden clutch you bought never seeming to disengage.
Old May 17, 2016 | 06:33 PM
  #2564
j_martin's Avatar
Old May 18, 2016 | 04:10 PM
  #2565
jimbo486's Avatar
Originally Posted by j_martin
Great song!!
