Old Jan 10, 2016 | 09:48 AM
  #1801
mknittle's Avatar
Originally Posted by Hillbilly66
My redhead showed up today, so I wheeled the welder out, threw a few beads across the frame, then put the box up. Just bleeding the air out of it, the steering felt so much tighter than the old wore out original.
Isn't that a good feeling
Old Jan 10, 2016 | 01:20 PM
  #1802
Hillbilly66's Avatar
Yes it is. I can't wait to get it on the highway to see how the old thing feels, now that practically everything under the front is new.
Old Jan 10, 2016 | 02:54 PM
  #1803
bigragu's Avatar
Hillbilly, who has the best price on that Redhead? Just want to note down who to call, should the time arise and I need a new PS unit
Old Jan 10, 2016 | 03:21 PM
  #1804
mknittle's Avatar
I am gathering parts to do pretty much the same thing. the only difference is when I last Drove mine it was 2wheel drive.
Old Jan 10, 2016 | 04:32 PM
  #1805
I ordered mine direct from Redhead $315 for the box, $150 core, (will get that back when they get my old box) round trip shipping to get it and to send the core back to south east Colorado was $68. I had to call because it wasn't on the website. Part number 2856SNI. I called them the morning of 1/6 and the gear was sitting at the post office for me to pick up yesterday morning 1/9. Very impressive shipping from WA to CO.
2wheel drive or 4 does it really matter, as long as you can drive it? mines been in the shop for so long that it's blocked in by two freightliners and two kenworths, I only thought I was going to drive it today.
Old Jan 10, 2016 | 07:10 PM
  #1806
mknittle's Avatar
Always somthing
Old Jan 10, 2016 | 09:01 PM
  #1807
Vader93's Avatar
Vader93, is yours a D or a W? If it's a 4x4 W250, is there anything out of the ordinary that you have done to your trucks fuel/air system to achieve 21 mpg's? All of what I've done is in my sig, and as far as fuel delivery modifications, I've tried to be conservative with pump tweaks, and have even down sized my injectors from those fuel guzzling POD's I used to run. I believe I have more air than fuel feeding my truck. How in blazes do you get 21 mpg's? Mind sharing?
Well i filled up for the 1st time today since injector swap. Mix of highway driving around 70mph, quite a bit of city and several play runs (hard launches and wot till speedo pegged out and then some). Still got 18.5mpg. Very nice i think. I'm going to run a tank strictly highway and easy shifts. Hopefully I'll break my previous mpgs. Still having alot of idle haze and have to be pretty easy on the throttle shifting to keep the smoke down. Either I've got my pump all wrong or i can't have my cake and eat it to. FWIW i run Stanadyne Performance Blend and Stanadyne Lubricity Formula at every full up.
Old Jan 10, 2016 | 10:54 PM
  #1808
bigragu's Avatar
Thanks, Hillbilly on the Redhead info. So far I've heard nothing but good on those units
Old Jan 10, 2016 | 11:18 PM
  #1809
Vader93's Avatar
In regards to this red head steering and I've also read some posts about a steering stabilize, is this more of a 4x4 upgrade or will i benifit much on a 2wd. My steering is nice and right but i have alot of body roll (in sure we all do). Just curious if this stabilizer will help much?
Old Jan 11, 2016 | 12:54 AM
  #1810
Was messin around with NV4500 shift tower and shift tower dust boots today....
https://www.dieseltruckresource.com/...3/#post3294059
Old Jan 11, 2016 | 04:09 AM
  #1811
You're welcome, I as well have heard they are supposedly the best, I sure hope they are.
If your steering is tight, and the truck doesn't wander, I don't think a steering stabilizer would do anything. Do you still have the sway bar under the front? They help more for body roll than a steering stabilizer.
Old Jan 11, 2016 | 06:56 AM
  #1812
Vader93's Avatar
Yes, factory sway bar is still in tact
Old Jan 11, 2016 | 07:13 AM
  #1813
Might check your bushings. I'm not aware of anything other than the sway bar to help with body roll. But then again I haven't looked for anything.
Old Jan 11, 2016 | 07:15 AM
  #1814
j.fonder's Avatar
stiffer springs, better shocks, bigger sway bar. you're driving a 6000 lb brick that not a single engineer who designed it was worried about body roll.
Old Jan 11, 2016 | 09:26 AM
  #1815
mknittle's Avatar
Exactly, There is lots of room for improvement.
