Old Mar 13, 2016 | 10:02 AM
  #2176
Ever see a hose leak through it's cords ?
New one was "MADE IN THE USA"...
Whodda thunk it ?
Attached Thumbnails What did you do to your Gen 1 today?-0311161222.jpg   What did you do to your Gen 1 today?-0311161415.jpg   What did you do to your Gen 1 today?-0311161444b.jpg   What did you do to your Gen 1 today?-0311161422.jpg
Old Mar 13, 2016 | 10:03 AM
  #2177
ofelas's Avatar
Where was the old one made ?
Whodda thunk it ?
Old Mar 13, 2016 | 10:04 AM
  #2178
It's the original one from Fuso. Made in 2006
Old Mar 13, 2016 | 10:07 AM
  #2179
mknittle's Avatar
Whodda thunk it ?
It is getting bad when we get excited about seeing a Made in USA label.
On a good note I have been seeing quite a few lately.Not nearly enough though
Old Mar 13, 2016 | 10:21 AM
  #2180
Heck, I'm excited to see "made in Mexico" as well. I've said it before, at least it's not made in china.. A lot of mexican made products are still made relatively well, by comparison.
Old Mar 13, 2016 | 10:35 AM
  #2181
mknittle's Avatar
Hung the ex rice farmer probably thinks he is doing really good to make shiny parts. Though nobody in the entire plant has a clue what it is.(but it is shiny)
Old Mar 13, 2016 | 10:56 PM
  #2182
Modified a spare ashtray so I could mount a rocker switch for the manual on/off control of the electric fans.....when I get it finally installed.
Lots of pics and info here....
https://www.dieseltruckresource.com/...4/#post3298965
Teaser pic....
Old Mar 15, 2016 | 05:46 AM
  #2183
bigragu's Avatar
Hey, TMan, where did you get the cooling fan from? Just noticed that. Does that have more blades than our OEM ones? How about the blade pitch angle? Designed to pull more air?
Old Mar 15, 2016 | 07:11 AM
  #2184
It came stock on the truck......
Japanese truck companies make some good stuff.....
Old Mar 15, 2016 | 09:53 PM
  #2185
bigragu's Avatar
That 3/4" torque wrench, where did you source that from? Non of the parts houses loan out a 3/4"; 1/2" is their largest. Going to check the rental yard next.
Harbor freight caries a 3/4 drive TW, but 300 ft lbs is the max
Old Mar 15, 2016 | 10:19 PM
  #2186
j_martin's Avatar
As I said before, I use a 3/4 breaker bar, a piece of pipe, a fish scale if I want to be precise, and my calculator.
Old Mar 15, 2016 | 11:19 PM
  #2187
1320Fastback's Avatar
We seem to forget these engines are industrial engines and were around a long time before Chrysler ever thought of putting one in a truck.
The 4BTs in our forklifts run dang near wide open for 8-9 hours a day.
Some have over 6,000 hours on them.
In the 16 years with my company I know of two turbo failures.
Old Mar 15, 2016 | 11:25 PM
  #2188
Bought this truck (my first cummins) in December.
Previous owner said he didn't know if KDP was fixed or not.
Truck is a 92 with 220,xxx on broken odometer so most certainly much higher.
Pin is recessed a fat 16th or slim 8th inch.
Going to make a tab and lock tight all the other housing screws.
Old Mar 16, 2016 | 12:49 PM
  #2189
j_martin's Avatar
It's walking. Tab it and you're golden. Don't forget to deal with the housing screws which are allowing the slight motion that makes it walk.
Old Mar 16, 2016 | 12:57 PM
  #2190
ofelas's Avatar
No amount of tabbing will stop your pin from recessing. It will stop it from walking forward into the timing case. You may find a couple bolts hard to get to without some creative tool making.
