Air cutoff for engine retarding?
I just had a thought. As dangerous as that is but could an intake air cutoff work to retard the engine when going downhill? If so, what would be the drawbacks of such a system?
Edwin
Edwin
I think it would cause massive oil consumption. Diesels are not typically set up to deal with vacuum on the valve seals, and the turbo seals wouldn't like it either.
Exhaust brake is a much better option.
OK please don't ridicule me for such a dumb question. I thought better of it as soon as I clicked the submit button.
But. Just as an academic exercise and as long as you kept the crankcase full, how bad would it be for oil to be sucked past the valve guides and compressor seal? AFAIK the compressor seal is just a slinger and the oil would just be burned or shot out the tailpipe as soon as you got back on it.
Curious in Kansas
Edwin
Curious in Kansas
Edwin
Valve guides wouldn't be bad, and on a non-intercooled truck the turbo seal thing wouldn't be that big a deal (other than the nasty smoke and associted deposit buildup). On an intercooled truck you'd get oil puddling in the intercooler, and you might get a big enough slug of it to hydro lock a cylinder when you built some boost and blew it through.
Wasn't a dumb question.
No air = no runaway. Maybe when you opened the air shutoff the engine would rev up on the accumulated oil, though.
Originally Posted by torquefan
It's not a bad idea at all, in theory. Unfortunately if you did it, it would suck in the preheater and intake manifold gaskets. You'd be replacing them all the time.
Edwin
This might be slightly off topic, but I have had the distinct pleasure of running a 1958 Mercedes Unimog once (25hp diesel, which I think is giving it alot of credit). The interesting part is that there is not throttle linkage hooked to the pump, only a shut down lever. Upon further investigation I traced a line going from the intake manifold to the injection pump, and before this line was a butterfly valve in the intake. The pump used vacum to throttle itself, what a goofy system, but it works (some how). Probably the only diesel I seen that runs vacum on the intake.
Fixitagain
Mar 24, 2007 06:08 PM
yannick
Feb 22, 2005 05:19 PM
joel
May 9, 2003 03:23 PM
