cutoff
Old Jun 1, 2004 | 06:54 PM
lgi40's Avatar
cutoff
My 96 dodge cummins 12v will not shut off with switch . maybe fuse . pulled the fuel shut off plug and it keep runing. if anybody has a clue thanks
Old Jun 1, 2004 | 09:03 PM
MnTom's Avatar
Did your starter stick? It could also be the relay on the firewall by the master cylinder. I vote for the relay problem. I just don't remember which one it is.
Tom
Old Jun 2, 2004 | 09:10 AM
infidel's Avatar
Are you saying you pulled the connector to the shutdown solenoid apart and it kept running?
If that's the case I say you have a rusted or gunked up solenoid or linkages.
Old Jun 2, 2004 | 07:12 PM
MikeR's Avatar
I would think that whe you unplugged it the spring would push the piston back down. Since it didn't I would start by taking it apart cause it seems the piston is bound up in the up position.
Dave88LX
Apr 4, 2007 02:10 PM
Fixitagain
Mar 24, 2007 06:08 PM
mhuppertz
Oct 31, 2006 01:39 PM
edwinsmith
Apr 16, 2006 09:14 AM
joel
May 9, 2003 03:23 PM
