3rd Gen High Performance and Accessories (6.7L Only) Talk about Dodge/Cummins aftermarket products for third generation trucks here. Can include high-performance mods, or general accessories. THIS IS FOR THE 6.7L ONLY!
Unplugging the EGR
Old Dec 7, 2008 | 05:16 PM
  #301
IL Ram's Avatar
Don't know what I did wrong but I didn't get the mpg's everyone else is. I got 16 highway one way and 14 back. 250 miles one way, had a bad head wind on the way home though. Anybody have a fooler or in the mix of making one for the egr delete yet?
Old Dec 7, 2008 | 07:55 PM
  #302
coolbreeze's Avatar
Were you towing?
Old Dec 7, 2008 | 09:18 PM
  #303
jsledder's Avatar
Right now, I'd be happy as heck to see 16!!! 14 would even be an improvement.... Best I've seen so far is 12.8, downhill with a tailwind.
Old Dec 7, 2008 | 10:18 PM
  #304
IL Ram's Avatar
Originally Posted by coolbreeze
Were you towing?
Nope, empty. The overhead said 18.5-18.9. Kept it under 70 too.
Old Dec 9, 2008 | 03:39 PM
  #305
kb7kuh's Avatar
Where is the EGR located?
Old Dec 9, 2008 | 03:49 PM
  #306
BroncoHound's Avatar
Bolted to the top of the intake, on the driver's side of the engine.
Old Dec 9, 2008 | 04:05 PM
  #307
Azzy's Avatar
Go to post #41
Old Dec 26, 2008 | 11:54 AM
  #308
Tree DR's Avatar
verification
Yes, I believe that's the issue that there is a sensor that detects no airflow and assumes the system is blocked so it puts the truck in limp mode because it thinks you need immediate service...
I have not seen this information varified anywhere and just wanted to make sure it was true.
Old Dec 28, 2008 | 04:52 PM
  #309
Tree DR's Avatar
Originally Posted by Azzy
On my 07 Chassis Cab build date 04/07 there is another plug just to the left of the one pictured in your photos. Any idea what it's for? Should I unplug it also?
Old Dec 28, 2008 | 10:53 PM
  #310
dj88382000's Avatar
INTAKE T/MAP sensor is mounted to the intake plenum / Air Inlet Assembly, just above the EGR Airflow Throttle Control Valve and below the EGR Valve Solenoid
Old Dec 29, 2008 | 03:23 PM
  #311
jsdavis84's Avatar
Quick question, someone may have already asked it but I haven't taken the time to read through all 20+ pages of this thread. I have the EGR blocker plates sitting at home right now, the truck is bone stock other than my DPF delete kit, no Insight or anythign like that. Will the truck go into limp mode when I install the plates or just throw the CEL without having any kind of tuner/mod?
Old Dec 29, 2008 | 04:36 PM
  #312
It will just throw a "soft" code CEL. No limp mode or anything like that. Just the annoying light on the dash.
Old Dec 29, 2008 | 09:11 PM
  #313
Tree DR's Avatar
So unpluging it is ok then. Should make my mpg go to 30 or better....
Old Jan 1, 2009 | 08:47 AM
  #314
Tree DR's Avatar
From what I've found the egr is not affecting mileage very much. Then the DPF must be the mpg killer along with the injectors fireing during the exhaust stroke.
Old Jan 8, 2009 | 01:05 PM
  #315
jsledder's Avatar
Will the EGR unplug mod cause the engine to idle eratically at times or "buck" when coming to a stop, reversing, idling, etc.. at times?
