Sponsored by:
Sponsored by: DashLynx
II boost question
Old 01-10-2010, 09:16 AM
dieselkid6's Avatar
II boost question
Got a good deal on a phat shaft 66 turbo and am goin to put it on with the mods in my sig. The boost is set to 40lbs n i was wondering if thats gonna be alright til i do the fuel system n studs this spring
Old 01-10-2010, 09:24 AM
Brian Lent's Avatar
I run 45 lbs with a 62 without studs for awhile. With stock injectors it will probably be hard to get 40 lbs out of a 66 though. I would put it on and look for some stix cause that's alot of turbo for stock stix. Just make sure it is up to operating temp before you get on it.
Old 01-10-2010, 09:32 AM
dieselkid6's Avatar
alright my plans are fass setup n prob 90 or 120 nozzles with arson III, valve springs and im gettin rid of the bullydog setup n goin smarty with tntr
Old 01-10-2010, 02:46 PM
2007 5.9's Avatar
Are you running a SPS66 or a PS66???
If your running the SPS, then anything up to 48psi is within it's MAP and DP won't be an issue.
If it's the PS, then your gonna have DP issues above 42-44psi. The PS hs a 65mm wheel and a 12cm housing which CR's will easily push DP ratio above 1.5:1.
Old 01-10-2010, 05:22 PM
bbbxcursion's Avatar
What's the Silver 64 good to?
Old 01-10-2010, 05:39 PM
2007 5.9's Avatar
Most II turbos are good to 47-50psi regularly. Provided they have at least a 71mm wheel.
The 65mm wheels are generally good to 43-45psi.
Old 01-10-2010, 06:36 PM
dieselkid6's Avatar
just the ps 66 n it has the 65 wheel n 14cm housing
Old 01-10-2010, 07:40 PM
Thanks for the info.
goose2w1
07-23-2008 10:49 PM
3500_CTD
14
02-05-2008 08:33 AM
TorqueJunkie
15
08-30-2006 09:15 PM
RockcrawlingTJ
07-22-2006 05:11 PM
GTSDave
07-08-2005 09:06 AM
Quick Reply: II boost question
