fuel pump question and boost question???
Old Feb 4, 2008 | 06:46 AM
3500_CTD's Avatar
looking to get a new fuel pump soon whats the easiest to install or do you have to get in the tank with any fp install on my year was thinking about that jeep fuel cage idea i herd slight things on here about it has any body done that also and how did that work out for you??
also just gonna throw this out at you guys see if you can make anything out of it when i got my truck my stock boost was like 30-32 psi i put the edge juice in and with the hot was able to hit 45 psi max now i only have the smarty in and im lucky if i can hit 28 psi gauge will come up pass 25 hit about 28 and shoot back down to 25 and stay there my egts seem like they have not changed as if i would have with a boost leak.
if any of you guys can help me with either one of these i appriciate it.
Old Feb 4, 2008 | 06:55 AM
jgiachino's Avatar
Are you running the aftermarket turbo version of smarty software? If not, it limits boost to stock levels (30-32psi peak).....check the version loaded in smarty by plugging it into the truck and seeing what ver comes up when you turn the key on....compare to the website....if you're already running aftermarket turbo version...guessing a boost leak.
Old Feb 4, 2008 | 07:05 AM
Fisherguy's Avatar
Use the search function, or just scroll a bit. There's TONS of options for fuel pumps different people have tried, I'm still trying to make a decision myself!
Old Feb 4, 2008 | 07:07 AM
3500_CTD's Avatar
yea i looked i had the question with the boost problem so i just posted them bothat once thanks tho
Old Feb 4, 2008 | 07:10 AM
Pinksa's Avatar
I had the same problem when i changed to the smarty from diablo...Aftermarket turbo program will make a huge difference
Old Feb 4, 2008 | 09:03 AM
mxg342's Avatar
Can I get away running the aftermarket program with a stock turbo?
Old Feb 4, 2008 | 02:13 PM
jgiachino's Avatar
Yes.....just dont abuse it by continuously pegging 40+psi.....try to keep'r below 40 and you're good to go.
Old Feb 4, 2008 | 02:26 PM
mxg342's Avatar
Sweet. That'll save me the $80 for the quad boost fooler.
Old Feb 4, 2008 | 02:41 PM
cincydiesel's Avatar
Try clamping off the hose going to the wastegate. I did this when my turbo was doing the same thing. Hitting 40psi with no problems
Old Feb 4, 2008 | 04:19 PM
3500_CTD's Avatar
yea how do you download the new programs i tried several times dont know if im missing something or what but i cant get it to work right i have windows vista if that makes a differance??
Old Feb 4, 2008 | 07:42 PM
jgiachino's Avatar
Make sure you download the 7zip program at the bottom of the download page (where the files are)...this program will allow you to unzip the file and they you shuld be able to upload to smarty...
Old Feb 4, 2008 | 09:04 PM
3500_CTD's Avatar
yea i did or think i did how do i unzip the file after i have that downloaded ??
Old Feb 4, 2008 | 11:04 PM
shortbed rv's Avatar
Right click on the file to be unziped and select unzip.
Is the aftermarket turbo program ok for towing 13k???
thanks
Old Feb 5, 2008 | 07:56 AM
jgiachino's Avatar
thanks
It'll keep the egt's much cooler....control with your right foot and no problem
Old Feb 5, 2008 | 08:33 AM
3500_CTD's Avatar
sounds good i'll give it another try when i get outa work thanks for the help guys
iamallcanadian
Mar 8, 2011 04:39 PM
goose2w1
Jul 23, 2008 10:49 PM
D.Wiggs
Jan 4, 2007 04:24 PM
RockcrawlingTJ
Jul 22, 2006 05:11 PM
GTSDave
Jul 8, 2005 09:06 AM
