Edge Juice and smoke
Well I finally decided on an edge with juice and I was just wondering how much it should smoke???? My rig is an 03 6spd and has an afe and 4 inch straight pipe
It must differ from truck to truck because when i run my Edge Juice on level 3 and stomp on the fun pedal it doesn't smoke all that much. It does smoke a little but nothing like i would like to see......
Mine smokes more than a 6spd. I think just because it takes more to get it rolling and my 3.73's are a little to high of gears for 35's, so I can lug it easy.Then it really smokes.
Today i had it on the edge on level 5 and decieded to womp on it...starting out in second and burned tire through 5th gear and she smoked pretty **** good for just having the edge box...but once adding fass system and bigger injectors..im pretty sure ill black out the highway
make sure you turn the low boost fueling all the way up....
but mine smokes a good amount lugging it....I love the tailgater trick! when i stacked my EZ it put out a little more smoke but not a lot...
I've had cars swerve to miss the black smoke...i love it.
8mpg
24
05-12-2006 05:44 PM
razor6
22
01-20-2006 03:43 PM
ataboy9026
12-28-2005 05:06 PM
