Can you run EDGE EZ and EDGE JUICE???
Old Dec 28, 2005 | 02:33 PM
ataboy9026's Avatar
Can these both be used together? I was going to get the new A2 controller with GPS with Juice and wondered about stack with EZ box. If not what would be good to stack with??? Anyone have the new A2 yet? How do you like it?
Old Dec 28, 2005 | 04:37 PM
bhoeffner's Avatar
Have not tried that stack, but I would think the only issue you would have is to much pressure to the common rail if you ran the juice and EZ together on the higher levels. The EZ is a pressure only box and I thought the juice was timing and pressure. Just my .02
Old Dec 28, 2005 | 05:06 PM
DR3500's Avatar
On an '03-4 you can't stack like you want since the Juice adds pressure like the EZ does, if you had a 600 then you could since its juice doesn't do pressure. If you want more I believe Edge is working on a Hot juice for ours.
I don't know of anything you could stack with the Juice or you will have too much of something.
Totallyrad
Jul 19, 2011 07:41 AM
Juiced01z06
18
Feb 13, 2007 11:46 PM
razor6
22
Jan 20, 2006 03:43 PM
