difference between edge juice and edge hot juice
Old Jan 18, 2006 | 04:35 PM
razor6's Avatar
ive been hearing alot about the edge hot juice with additude and regular juice with additude and was wondering if someone could please tell me what the difference is. thanks
Old Jan 18, 2006 | 05:23 PM
hognutz's Avatar
well obviouly the 80hp. I don't know exactly were it comes from though. I would like to know as well. I stated a box matrix and I have some question marks on the hot juice.
Old Jan 18, 2006 | 07:13 PM
RamWheelsBy4's Avatar
For 04.5 325/600 up
Edge Juice/Attitude
Level 1 25hp 80torque
Level 2 40hp 120torque
Level 3 60hp 150torque
Level 4 80hp 200torque
Level 5 100hp 250torque
HOT Juice/Attitude
Level 1 40hp 120torque
Level 2 60hp 150torque
Level 3 80hp 200torque
Level 4 100hp 250torque
Level 5 180hp 440torque
According to Edge the equivalent hp levels are the same programming in the HOT Juice/Attitude you just loose 20hp Level and gain 180hp Level.
Old Jan 18, 2006 | 07:22 PM
hognutz's Avatar
Originally Posted by RamWheelsBy4
For 04.5 325/600 up
Edge Juice/Attitude
HOT Juice/Attitude
is it all timing and duration based.
Old Jan 18, 2006 | 07:23 PM
razor6's Avatar
will the hot juice/additude blow ALOT more smoke than just the regular juice with additude or the same?
Old Jan 18, 2006 | 08:07 PM
Goggleyed's Avatar
According t Edge, the HOT box can be either +60hp or +80hp (on top of the Std box) depending on which ECM flash you are running. Evidently the newer flashed are resulting in a 20hp drop. It would be interesting to see someones dyno results.
Old Jan 18, 2006 | 09:23 PM
Hot Juice/Attitude for 04.5 600 up all timing and duration.
HOT Juice/Attitude with EZ stacked on my truck dyno'd 479rwhp on DynoJet, no torque numbers. This was right at 200rwhp over completely stock dyno number. This was with air intake, exhaust, FASS and SPS66 turbo.
Old Jan 19, 2006 | 06:40 AM
tristan21's Avatar
What do they charge and how long does it take to get them to do the std. to hot box reprogramming? And can anybody tell me if they have any breakage problems on the hot box extreme setting?
Old Jan 19, 2006 | 09:32 AM
hognutz's Avatar
I do belive it is $100. there is a form on there site. if you look at the form it say tdr member # (free). I don't know if that means free to TDR members?
as for turn around time I have no clue.
http://www.edgeproducts.com/pdf/RMA/..._DodgeDrag.pdf
Old Jan 19, 2006 | 11:22 AM
RankRam's Avatar
Yes it's free for TDR members.
Old Jan 19, 2006 | 01:47 PM
hognutz's Avatar
that is cool get a $100 upgrade for a $35 subscription.
Old Jan 19, 2006 | 04:41 PM
Igor's Avatar
I would imagine you need more supporting mods to ever even use leve 5 on the "hot" juice...
I think I want to try the hot juice, and maybe eventually an EZ stack w/hot juice, but, I think I need tranny/turbo/inetercooler/fuel pump mods to take advantage of the new found power....
Any of you guys running the Hot juice, what other mods do you have?
Thanks.
Old Jan 19, 2006 | 05:33 PM
djgaston's Avatar
A fried clutch. Still saving up for my SBC DD clutch.
Old Jan 19, 2006 | 08:51 PM
razor6's Avatar
if i got an upgrade from my regular edge to the edge hot juice will it blow out more smoke on high settings or about the same. does anyone happen to know? thanks
Old Jan 19, 2006 | 08:54 PM
Thanks.
When I ran the HOT Juice/Attitude and EZ stacked I had TC/Trans(All Billet Shafts), FASS, Air Intake, exhaust and SPS66 turbo upgrades. Very good stack combination for me. I could use all the power the HOT Juice/Attitude and EZ Stacked could provide..
