difference between edge juice and edge hot juice
ive been hearing alot about the edge hot juice with additude and regular juice with additude and was wondering if someone could please tell me what the difference is. thanks
well obviouly the 80hp. I don't know exactly were it comes from though. I would like to know as well. I stated a box matrix and I have some question marks on the hot juice.
For 04.5 325/600 up
Edge Juice/Attitude Level 1 25hp 80torque Level 2 40hp 120torque Level 3 60hp 150torque Level 4 80hp 200torque Level 5 100hp 250torque HOT Juice/Attitude Level 1 40hp 120torque Level 2 60hp 150torque Level 3 80hp 200torque Level 4 100hp 250torque Level 5 180hp 440torque According to Edge the equivalent hp levels are the same programming in the HOT Juice/Attitude you just loose 20hp Level and gain 180hp Level. |
Originally Posted by RamWheelsBy4
For 04.5 325/600 up
will the hot juice/additude blow ALOT more smoke than just the regular juice with additude or the same?
According t Edge, the HOT box can be either +60hp or +80hp (on top of the Std box) depending on which ECM flash you are running. Evidently the newer flashed are resulting in a 20hp drop. It would be interesting to see someones dyno results.
Originally Posted by hognutz
is it all timing and duration based.
HOT Juice/Attitude with EZ stacked on my truck dyno'd 479rwhp on DynoJet, no torque numbers. This was right at 200rwhp over completely stock dyno number. This was with air intake, exhaust, FASS and SPS66 turbo. |
What do they charge and how long does it take to get them to do the std. to hot box reprogramming? And can anybody tell me if they have any breakage problems on the hot box extreme setting?
I do belive it is $100. there is a form on there site. if you look at the form it say tdr member # (free). I don't know if that means free to TDR members?
as for turn around time I have no clue. http://www.edgeproducts.com/pdf/RMA/..._DodgeDrag.pdf |
that is cool get a $100 upgrade for a $35 subscription.
I would imagine you need more supporting mods to ever even use leve 5 on the "hot" juice...
I think I want to try the hot juice, and maybe eventually an EZ stack w/hot juice, but, I think I need tranny/turbo/inetercooler/fuel pump mods to take advantage of the new found power.... Any of you guys running the Hot juice, what other mods do you have? Thanks. |
Originally Posted by Igor
Any of you guys running the Hot juice, what other mods do you have? |
if i got an upgrade from my regular edge to the edge hot juice will it blow out more smoke on high settings or about the same. does anyone happen to know? thanks
