Edge juice and black smoke
Man, my edge POURS it out and I have stock inj. and everything....well a new fuel system helped that a lot too! I can pretty well Black out an intersection, a lot more than what guys were telling me. I am pleased with it!!! Read the manual on the low boost fuel settings. Not hard but I can't remember off the top of my head. I just have all my sub settings turned all the way up.
I hardly get much smoke at all with my edge/juice. I keep it below level 3 and usually below level 2 though, since I have a stock auto trans. I do have a brand new dodge lift pump, BD aux pump kit, new in take sending unit, and a VP44 that is only 30k miles old. My fuel pressure is @ 30-32psi at idle and doesn't go below 27psi at wot.
Maybe it is volume that I need?
What exactly is a AFS Big Dog Fuel System?
It's kinda the same setup as the bigline kit. Not just a new pump, but all new, bigger fuel lines. The regular kit has the pump and bigger lines from the tank to the filter. The big Dog kit has that plus bigger banjo bolts and lines from the stock filter to the injection pump. The banjo bolts have NO restriction it's a hollow bolt. My stock bolt had a deal in it like on a tire valve for air. There's a lot of volume pumped in it now and actually once I put it on it seemed to have a little different tone to it while idleing, kinda smoother when at idle. You can look it up on Glacier's website
dieselTrain
Jun 17, 2006 04:22 PM
8mpg
24
May 12, 2006 05:44 PM
razor6
22
Jan 20, 2006 03:43 PM
bensdad_canada
May 9, 2005 10:56 PM
