Saving a '91.0 W-250
I bought a West coast W-250 at the end of last winter.
I have been slowly chipping away at the big issues.
The Getrag was in such sad shape it would barely limp on my trailer without popping out of EVERY gear.
The smell of gear oil was strong as it leaked rapidly out the 'Rag
Things that have been done and why:
Rebuilt ANOTHER Getrag due to the last guy running 75/90W in it in the WINTER
Disassembled, checked out and resealed output yokes the NP-205 due to it being almost empty when I got it.
South Bend clutch installed when out, because I will need it later to hold the power.
Trans cooler plates installed on the PTO covers on the 'Rag and filled with Mobil 1 5W-30.
Driveshaft U-joints replaced.
All other fluids where checked, changed or had fluid added as needed.
Checked brakes rotors, pads and lines.
Tightened the E-brake cable.
Some wiring needed to be done, as the Headlights came on when you put it in reverse.
At that point I got a plate for it and started driving it to sort out other things it would need.
I have done a bunch of other little stuff to it since getting it on the road, that I will detail better later.
One of the big things I have to do is, gut almost the whole interior.
The story goes something like this:
Some guy flies out to Oregon and buys a solid 1st gen.
Then he gets a Husky puppy.
He spends several months working the "harvest" season down the coast. He lived in the truck, during this time, under this crazy looking gypsy style camper.
At the end of the fall he drives it back out East from Cali..
The dog looses its mind in the cab by the look if it, as it must have WANTED OUT for a while.
I own 4 English Mastiffs. I have also owned more old Dodge trucks through the years than anyone else I know, and I have NEVER seen an interior so throttled.
I think some of my friends here will load a few pictures on the thread, so it is more exciting for the picture hungry crowd.
Thanks Thrashing!
My new pup is checking for loose tie rods in the front end.
AKC and ASE paperwork on that one!
The other shots are of my two beer, two hammer, two hour body work mission on the dented front fender.
The other is a quick make shift jig I made for getting an OEM Mopar windshield down to the shop to get it put in.
They only charged me $40 to install it.
Yesterday, I cleaned out the drivers door and sprayed it down with Fluid Film on the inside to prevent rust.
Got the window crank lubed up and working smoothly.
Removed the wires for the door open buzzer, I always hated that noise. I can tell when my door is open fine on my own. I don't want my truck telling me what I already know I am doing.
I tried to get my upgraded speaker to work, but the factory wires for it seems to not be working.
I chased them back behind the dash a little.
After tinkering on it for a bit, I cracked a beer and had dinner.
Walking away BEFORE you get frustrated is the best way to keep projects FUN!
Yeah, so what if I am driving around with no inner door panel and only mono speaker for a few days till I throw another hour or two at it.
This morning I bent up the left rear brake tube. I still need to cut and flair one end but I have a appointment with my Oncologist this afternoon. so that is one of the things that frustrate me the most.
I drove from FL to AK without a radio😬. No judgement here
Truck looks like a good summer 1st gen beater!
I have been having fun driving it around town and such.
I got the chance to play with the fuel screw and do some pump tuning last week.
Once I took the tamper proof cap off the fuel screw I could see that it was almost bottomed out on the "safety" collar. I only got an 1/8 of a turn before it maxed out against the collar.
That was not going to cut it, so out it came.
I put it in my vise and I pried the collar off, clean up the threads a bit and screwed it back in. I then turned down the idle using the idle screw, spun the fuel pin to the deep side, adjusted the throttle rod, backed off the smoke screw two turns and took it for a drive.
Much better.
Much better.
