Got my Edge Juice... wheres the juevos and the smoke?
Installed the juice kit today on the 06 an am runnin on EXTREME (level 5) but there isnt much ***** behind it. My04.5 with the bullydog power pup on the 90hp setting had more ***** and more smoke. I barely get any smoke on all the levels...maybe I need hot juice. Anyone else not impressed with the kit?
Originally Posted by 8mpg
LOL..
Well, I went back out and played around and it feels like there is more power but not quite the same as the power pup. Im gonna call tomorrow for the hot juice.
However, that's not stopping me from sending mine in for the HOT update
- I'm taking it off on Monday to ship.
Originally Posted by omaharam
Mine sets you back in the seat at any speed or rpm. If you want smoke, you have to go into the sub menu and there is adjustments for each of the five main settings. Trust me, on level 5 with the sub menu level set on 5, it smokes.
- I'm taking it off on Monday to ship.I will have to check out the sub levels...gotta have smoke
Originally Posted by NOTSTK
My 03 don't smoke much either.. Not like my 98 12v with the #10 plate full fwd. Me need more smokey too... I might check out the Hot Juice too.
what do yall think is needed to safely run the Hot Juice? fuel system upgrade? turbo?
My Juice/A2 is scheduled to be put in next week along with a DTT tranny, AFE Stage II, and a FASS 150gph. I'm highly considering get the Hot upgrade right off the bat.
. The only thing I would say is the stock turbo will not be able to keep up with all the added fuel from the hot juice....
Originally Posted by Dan Marino
Not Impressed???? Mine is updated to HOT or EXTREME -whatever. The tech at Edge wrote EXTREME update on mine so Ill call it EXTREME. Even on race setting level 4 I can smoke 2 tires and a tailpipe. On the Extreme level 5 I can smoke 4 tires and black out a parking lot. I have the menu set on most smoke and performance though. I have to say I am super impressed with the EDGE JUICE for my truck. Only problem I got is defuel TQ management at launch. Solving that with a BD race box though.
8mpg if you still have your BDPP just stack the two nd then it will really smoke. Ask me how I know.
The stock turbo is fine even with the "HOT" Juice. I've got dyno proven 500+hp truck still on the stock turbo.And I still haven't upgraded to the HOT program. An upgraded turbo is on it's way though, only cause with all the unburned fuel and smoke i see now, I prob got 50hp of untapped power that is not being utilized.
The reson you don't feel the power of the Edge more is cause they are not as aggressive in pressure and timming on the low end like the Bully Dog, and has alot better and smoother top end. Belive me I know. I've done quite a few timed runs using that 1/4mi timer on the Edge. I thought the same thing, that the BDPP had more pwer on 90hp than the Edge does at 100hp. every run i have done on those 2 individual settings prove otherwise however. The power of the BDPP comes on quicker, but dies off sooner also and has a flat spot around 80-90mph. The Edge has a lot smoother transition and much bettter midrange without the crazy throttle respose. And when I have them both on, well just hold on to your hats cause I'm outa there
The stock turbo is fine even with the "HOT" Juice. I've got dyno proven 500+hp truck still on the stock turbo.And I still haven't upgraded to the HOT program. An upgraded turbo is on it's way though, only cause with all the unburned fuel and smoke i see now, I prob got 50hp of untapped power that is not being utilized. The reson you don't feel the power of the Edge more is cause they are not as aggressive in pressure and timming on the low end like the Bully Dog, and has alot better and smoother top end. Belive me I know. I've done quite a few timed runs using that 1/4mi timer on the Edge. I thought the same thing, that the BDPP had more pwer on 90hp than the Edge does at 100hp. every run i have done on those 2 individual settings prove otherwise however. The power of the BDPP comes on quicker, but dies off sooner also and has a flat spot around 80-90mph. The Edge has a lot smoother transition and much bettter midrange without the crazy throttle respose. And when I have them both on, well just hold on to your hats cause I'm outa there
