Manual high idle
Old Jan 25, 2005 | 07:44 PM
GBB's Avatar
GBB
Manual high idle
How do you activate the manual high idle and to you have to have the current reflash?
Old Jan 25, 2005 | 08:35 PM
bulabula's Avatar
On automatic transmission trucks, once the high idle is enabled by the dealer, you control it by using the cruise control functions on the steering wheel.
I don't believe the "current reflash" has anything to do with enabling the high idle feature - 2 separate animals.
Old Jan 25, 2005 | 08:38 PM
eastmentCTD600's Avatar
just had my 04.5 reflashed and the manual high idle function enabled. I don't believe it had the option for the enble from the factory. I know it come wih TSB 18-037-04.
Old Jan 25, 2005 | 08:56 PM
procrastinator's Avatar
will the high function work on manual trucks too?
James
Old Jan 25, 2005 | 09:19 PM
tool's Avatar
Wish you could use this feature on the 2nd gens.
Old Jan 26, 2005 | 01:55 AM
Hounddog's Avatar
Not on manual trans trucks.Not on older trucks at all.Has to do with ecm's.After 03 its all CUMMINS. Before it was mixed Cummin/DC.
Old Jan 26, 2005 | 07:17 AM
phloop's Avatar
Re: Manual high idle
You take about a two/two and a half foot long chunk of broom handle, jab it in between the pedal and seat and run the seat forward to your desired idle speed. Of course, you will get finer tuning of the idle speed if you have power seats. From what I've read, you do not need the TSB 18-037-04 flash, the tech just needs to enable and then turn on the manual high idle feature. When I tried having my trucks high idle turned on prior to the reflash, the tech had enabled the idle but did not turn it on. And the high idle will not work with the manual tranny trucks, so if you have one you might look at my hill billy high idle stick a tad bit closer.
Old Jan 26, 2005 | 11:01 AM
Thanks,
Too bad it doesn't work with manuals. I thought it would be nice to hide my "ozark tire thumper" out of site from the guys at work when I am warming my truck up in the mornings.
James
Old Jan 26, 2005 | 11:31 AM
bigblock2stroke's Avatar
look for a mopar clutch switch soon.
Old Jan 26, 2005 | 12:36 PM
Hounddog's Avatar
Well I got MY manual high idle to work today.ONE little problem! I used a universal choke pull cable.Minor hole in rt side lower dash,drilled through upper part of fuel pedal linkage etc.hooked it up and it will work with no binding etc.BUT I need a pull cable that will lock!One that if you turn **** to the right will stay locked where you want it. A SMALL cable control that locks on top of that.Not something large.
Old Jan 26, 2005 | 05:06 PM
bhoeffner's Avatar
I believe the only way to get it is with the TSB reflash.
Old Jan 26, 2005 | 05:53 PM
Hounddog's Avatar
Its not avalable on 03 or below or manual transmissions.I need a cable that locks.What I installed works great if I can come up with a cable that locks at a twist no larger then the unverisal fit hand throttle I came up with.Total cost I have in mine is less then $12.00. BD makes a electronic one.$400.00 and its basicly only a SINGLE speed.Said with another toggle switch in the circuit it could be two speeds.WOW thats nice.
Old Jan 27, 2005 | 08:54 AM
jbrown2861's Avatar
Look in JC Whitney, there is a cable actuator for the front differental that replaces the vacumn actuator. It has the lock you are looking for.
Old Jan 27, 2005 | 09:34 AM
phloop's Avatar
Also try Graingers or Northern. I think I have seen control cables like that in both of their catalogues.
Old Jan 27, 2005 | 09:48 AM
Hounddog's Avatar
Thanks!
ajpulley
102
Dec 31, 2010 02:03 AM
kicker210
Dec 2, 2009 08:23 AM
jmccart
Jun 12, 2007 02:12 PM
STATELINE
42
Nov 25, 2005 05:05 PM
Patrick Campbell
17
Dec 2, 2003 08:03 AM
