Manual Trans high idle
Old Nov 17, 2005 | 03:47 PM
ajpulley's Avatar
Well, wouldn't you know it. I went to the dealer today to have the high idle feature enabled. I showed them page 226, and TSB 18-004-04. They still said it couldn't be done, untill... I spoke with DC, and they called the dealership. Now, they are calling thier district rep trying to figure out how to do it. DC also gave me a phone number for Cummins. When I spoke with them, he told me about the feature, and that it was available on both transmissions.
So, I asked if he would fax the bulletin to me. The Cummins bulletin number is 4907665. On the bottom, it reads "Revised 24-Jan-2005". It mentions this is an available option on all 05 models, auto or manual. If, however, it has a manual, it requires a clutch switch kit; Cummins P/N 4089851, Mopar P/N 05175417AA. It is said to work the same as if you had an auto, except if a Jacobs engine break is installed, the limit will be about 1,350 RPMs. I don't know if this has been posted. If not, maybe it will help someone out.
In the meantime, time to make some more phone calls for myself.
Old Nov 17, 2005 | 03:50 PM
mishkaya's Avatar
Let us know how it turns out as many of us with the manual transmission would love to have this feature.
Mishkaya
Old Nov 17, 2005 | 03:51 PM
ajpulley's Avatar
Sorry, I have the auto trans. But, I just wanted to post it so maybe someone who has a manual might enjoy this feature.
Old Nov 17, 2005 | 05:27 PM
MikeyB's Avatar
We already have a clutch switch installed. The clutch need to be pressed down to start the engine.
MikeyB
Old Nov 17, 2005 | 05:43 PM
4x4not's Avatar
I will keep an eye on this thread! I really want that feature
Old Nov 17, 2005 | 06:42 PM
bkrukow's Avatar
Knowing my luck they will claim its not available for the 04.5 trucks taht are identical to the 05s.
Old Nov 17, 2005 | 07:45 PM
Shepherd57's Avatar
Will this work on the 03 6 speeds
Old Nov 17, 2005 | 10:20 PM
ajpulley's Avatar
Guys, I know you have "a" clutch switch that allows you to start the truck. I'm fairly sure that the engineers at both Dodge and Cummins know that too, otherwise they wouldn't have come out with another new part and part number. And, I don't know if it works on an 03 or 04. I spoke with a guy named Tom at Cummins Customer Support Center. The number given to me by a rep at DiamlerChrysler was 1-800-343-7357.
I have an automatic, so info on a manual is a waste of my time. As a courtesy, I'm just passing on what I found out to those of you who want this feature on your manuals and might like to investigate it for yourselves.
Old Nov 18, 2005 | 07:32 AM
jawmail's Avatar
No, only '04 and up autos. You are ol.
Old Nov 18, 2005 | 11:35 AM
DR3500's Avatar
MikeyB
Yes we do but it doesn't give the safety input the high idle feature wants, it wants the clutch engaged so it knows that if you push the clutch to put it in gear that it will return to normal idle.
Old Nov 18, 2005 | 06:19 PM
rudy's Avatar
Well, I have a 05 with a 6 speed in it, and when it is below 34 F it will idle up to a 1000 rpms untill the engine temp. is higher than the outside.
Old Nov 19, 2005 | 09:48 AM
RC51's Avatar
Can you scan a copy of the faxed bulletin from Cummins?
Old Nov 19, 2005 | 10:47 AM
BEHRMAN's Avatar
FWIW...Mine does the exact same thing! 03 with 6 speed
Old Nov 19, 2005 | 11:00 AM
STATELINE's Avatar
yes, they all do this, what we're talking about here is the driver controlable high idle that is controled thru the cruise control buttons, & can be set between 1000-1500 RPM, & so far is only available on auto trans trucks
Old Nov 20, 2005 | 09:42 AM
CRXsi's Avatar
I really hope this is true! The next question then is...is it covered under warranty the same as the autos are if you complain about poor heat or whatever the bulletin was for. Or are we on the hook for paying for not only the switch but also the flash as well?
