High idle, and 3cyl high idle
Old Nov 29, 2009 | 07:16 PM
kicker210's Avatar
Does anyone know if the 02 with manual tranny has this option? I've had a couple dealers tell me they dot have that option but I've seen several people on here with the same truck and they have high and 3cyl idle. I need any and all info on this if you guys can help me. It's rapidly getting colder here And my truck has to sit out and I'd really like to have this option. Thanks all.
Old Nov 29, 2009 | 07:22 PM
Dr. Evil's Avatar
Nonsense - Most dealers couldnt buy a clue, which is a shame.
Yes, it will work on your truck. Works on my 01 6 speed anyway. There are numerous conditions that must be met to get it to actuate.
Where are you? The easiest thing to do is to buy a Smarty or find someone that will let you try theirs. When they take it off, the high idle and 3 cylinder idle will remain enabled. Check out your local DTR Chapters - I guarantee there is some good guys there that would be more than happy to help you out:
https://www.dieseltruckresource.com/...vents-f96.html
Old Nov 29, 2009 | 08:18 PM
99 24v's Avatar
^ditto use a smarty, worked on mine, installed it and then removed it and now have high idle
Old Nov 29, 2009 | 08:25 PM
kicker210's Avatar
Anyone live in okc with a smarty ?
Old Nov 29, 2009 | 08:32 PM
Purplezr2's Avatar
Anyone in MN with a smarty want to help me out
DodgeCowboy's Avatar
DTR's Cow Boss
Mine works to my high idle kicks in when the out side temp is in the 20s and the 3cyl kicks in when its in the teens and lower. Man its sure handy when its cold specially if I kick in the exhaust brake
Old Nov 29, 2009 | 10:47 PM
johnh's Avatar
my high idle and 3 cyl work as it is supposed to, but the 3 cyl won't kick in until below zero......... i expect the temps to get down in the low teens tonight,
Old Nov 30, 2009 | 09:31 AM
johnh's Avatar
actually it got down to 5 this morning....no 3 cyl
Old Nov 30, 2009 | 12:04 PM
graphitecumnz's Avatar
if you're planning any trips to Wichita, I can help you out....
Old Dec 1, 2009 | 10:00 AM
RowJ's Avatar
Same here...if you get down near Durant, OK!
RJ
Old Dec 1, 2009 | 09:45 PM
kicker210's Avatar
Thanks for the offer if I could ever get a day off work from both jobs it would well be worth the trip
Old Dec 2, 2009 | 12:39 AM
Nick02Ram's Avatar
I had the same problem, 5 different dealers all looked at me like I was crazy...i still ain't got it flashed yet. Even showed em in the manual where it says it is available and to see the dealer
Old Dec 2, 2009 | 08:23 AM
nickg's Avatar
here is a tsb, print it off and give it to the dealer, I had no luck the dealer charged me 100$ and it still did not work, found a local guy who used his smarty...now my high idle works
http://dodgeram.info/tsb/2001/18-019-01.htm
heres another old thread on how to fool the APPS
https://www.dieseltruckresource.com/....html?t=123156
13ALPHA
33
Feb 7, 2010 12:22 AM
checkster
39
Feb 1, 2008 02:41 PM
2001 CTD
Jan 15, 2008 03:51 PM
CRSmith
17
Feb 5, 2007 07:43 AM
Bradtothebone
0
Dec 11, 2003 10:36 PM
