dead injector pump?
Old Nov 29, 2009 | 09:07 AM
dead injector pump?
I am looking at a truck to buy that starts and idles but the pedal does nothing. If the truck still starts is it the lift pump or the injection pump that died. Could be throttle cable but he said a shop said needs a pump and estamated the job at 3000.00. '01 24V truck Thanks
Old Nov 29, 2009 | 09:37 AM
johnh's Avatar
could be the throttle position sensor... use a scanner to pull any codes and go from there.
Old Nov 29, 2009 | 09:39 AM
olbetsy98_12V's Avatar
Injection pump
It sounds like the injection pump. Does it start up right away or does it take longer than normal? We had an injection pump go bad on a truck and it took a long time to start and it would idle just fine but it didnt have any power. But usually if the injection pump goes out it is cause by the lift pump goin out first. I take it that the truck doesnt have a fuel pressure gauge? And by the way the $3000 is way to much money to change one of those pumps.
Old Nov 29, 2009 | 09:40 AM
Injection pump
You are right johnh I would check that sensor first.
Old Nov 29, 2009 | 09:42 AM
DieselNoob's Avatar
What codes are showing? Here's an excellent write-up on how to diagnose VP44 problems
FWIW if it is the injector pump you can buy one and install it yourself if you're fairly handy with tools. The injector pump runs around $1000 and the lift pump (if you need one) runs $300-400.
Old Nov 30, 2009 | 08:12 PM
dozer12216's Avatar
Do three key on trick to read codes. 216 and 1693 good indication of VP fail. Will they reduce price by $3000.00?? Try for $4K off if really intrested. DIY and save.
Old Dec 2, 2009 | 12:57 PM
gunslingeraz's Avatar
Dead Pedal
I've had my truck since 2000 and have not had any problems until now..... Reading all these posts today has me replacing my pick up pump, the VP44, Cam Sensor and checking the cable as well. I have no idea where to start. I do have a "dead pedal" or close to it. Truck starts fine and idles fine but I have noticed a power surge/cycle in the amps and it takes 5-10 minutes for it to straighten out to the normal 14.5 amps. I know the glow plugs take a few amps but they are new Optima yellows. After initial warm up, the pedal will go to the floor and I get a slow increase in mph to the point of 28-30 mph in first gear and then a shift to 2nd. If I keep the pedal to the floor, it will slowly increase to 35-40 mph and shift to 3rd. It goes like this until something gives or resets and full power is restored. Then and only then can I let off the pedal to resume normal driving with one caviot. At 55-60 mph or towing my boat, it will go to dead pedal if I don't constantly move the pedal or let off entirely to idle, push it to passing gear or "remash" it to restore it to normal. All of this is habit for me now but I am afraid it's going to hurt something else if not fixed soon. Can you help?
Gerry
sparky10
Aug 23, 2007 09:04 AM
93' Shorty
May 31, 2007 08:30 PM
Jake R.
Jan 16, 2006 11:45 PM
georgemgeorge
18
Jul 1, 2005 08:05 PM
