"dead pedal"/injector pump?Help!
Old Aug 17, 2007 | 03:56 PM
sparky10's Avatar
I have a 2002 Dodge 2500 with a 24 valve HO cummins and a 6 speed manual transmission. What causes loss of power and no response from the accelerator pedal when I slow down to 50 - 55 MPH? It doesn't happen all the time, but when it does, I can downshift or press the clutch and rev the motor and it seems like something resets and the truck takes off again. This also happens if I just start the truck and take off without letting it sit and run for about 5 - 10 minutes. I have changed the fuel pump, fuel filter, and air filter with change in performance. If anyone can give me some insight on this very frustrating problem, it would be greatly appreciated.
Old Aug 17, 2007 | 03:58 PM
sparky10's Avatar
correction to my original post: changing the fuel pump, fuel filter, and air filter produced NO change in performance
Old Aug 17, 2007 | 04:16 PM
blackdiesel's Avatar
Registered
Key on, off, on, off, on and watch your odometer to get codes. probley on 0216 and a dieing IP, but only the codes know for sure. SORRY
Old Aug 20, 2007 | 08:27 PM
sparky10's Avatar
Thanks for the info! I read the following codes: 1693,0230, & 0216. What are 1693 & 0230 telling me?
Old Aug 20, 2007 | 08:31 PM
Registered
230 is trasfer pump curcit out of range. 1693 is a code in the pcm telling you theres a code in the ecm.
Old Aug 20, 2007 | 09:37 PM
J BODY's Avatar
....and p0216 is "pump timing failure". That COULD be a problem.
Old Aug 21, 2007 | 08:52 AM
sparky10's Avatar
Ok, the "pump timing failure" thing - can this be corrected with an adjustment or does the whole pump have to be replaced (trying to get around spending $1000+)? Also, code 230 "transfer pump circuit out of range" - is this one a result of the injector pump or is this a seperate issue? Thanks for the help!!
Old Aug 21, 2007 | 09:13 AM
Dr. Evil's Avatar
Some will say that they drove for 6+ months with the 0216 code - but you are really risking being left on the side of the road and possibly an expensive tow. They Injector Pump is likely shot. I see youve already replaced the lift pump so part of the job is done.
Get yourself a fuel pressure guage, if you dont already have one.
Old Aug 21, 2007 | 11:12 AM
Registered
If I were working on your truck, I would find out where this 230 code is coming from first. It's not a common code to have. There is a SLIGHT chance it could have coused the 0216, BUT I have yet to see an 0216 with dead peadle fixed with out a new vp44. JMO
Old Aug 21, 2007 | 11:53 AM
sparky10's Avatar
Old Aug 21, 2007 | 09:06 PM
J BODY's Avatar
That is true Black D....Personally whenever I see that code you get a new lift pump. Most likely the lift pump motor went "open" at some point in time to cause that code. So, new lift pump, make sure the filter is new (or fairly new)....and then I clear the codes and test drive it at 2800-3000 rpm's for a mile or so. Seems kind of harsh, but it doesn't hurt a thing and if a P0216 is going to set in short order, it's that kind of test that I've found to make it happen.....if so, then you get the BIG pump (VP).
Old Aug 21, 2007 | 09:55 PM
Dr. Evil's Avatar
He said that hes already changed the lift pump so thats already done.
Old Aug 22, 2007 | 07:30 AM
Clunk's Avatar
I've had success with a dead pedal isue by disconnecting then reconnecting the wiring connection to the throttle position sensor...accelerator pedal position sensor(APPS). You can also try resetting the APPS.
A fuel pressure reading could be helpful here, some new lift pumps are bad right outof the box.
Old Aug 22, 2007 | 08:18 AM
J BODY's Avatar
True....so that's where I clear the codes and run it as described above. If code shows up...VP time. If no code I turn it loose and tell them to stop by so I can scan it, or return asap if "dead pedal" occurs so we can see what code shows up.
Old Aug 22, 2007 | 09:18 AM
Dr. Evil's Avatar
Good Luck Sparky....and like I said before:
Do yourself a favor and get a fuel pressure guage
