Truck is dead (injector pump problems??)
Old Jan 7, 2006 | 06:21 PM
Jake R.'s Avatar
Friend has got a 92 cummins and he tore the injector pump off to get it rebuilt. Put it back on and the truck wont even fire just puff out white smoke. What are we doing wrong??
Old Jan 7, 2006 | 07:18 PM
RickCJ's Avatar
What is the timing set at?
Old Jan 7, 2006 | 10:39 PM
midwestdually's Avatar
if it just got rebuilt it is not dead
Old Jan 8, 2006 | 05:13 PM
ctd89-99's Avatar
No start
You're way out of time.
Old Jan 8, 2006 | 05:22 PM
TIMMY22's Avatar
180* out? easy to do...
white smoke means you have fuel, just at the wrong time.
Old Jan 8, 2006 | 09:26 PM
Jake R.'s Avatar
thanks for everything the timing gear on the pump was retarded two teeth because my friend screwed up putting the gear back on the pump. This site is awesome you guys know everything thanx a millon
Old Jan 8, 2006 | 09:28 PM
phox_mulder's Avatar
Well, not everything, but the combined knowlege here is astounding.
phox
Old Jan 16, 2006 | 05:08 PM
ibuiltmine-o1oo's Avatar
Just for your information, you know if you even touch that taperd shaft with bare hands, it can slip in that gear! letalone if it had wd40 or even grease or something on it...weve had a couple HOT trucks come through here wondering why the heck everytime they stomped it it would go outa time.....alcohol, and lots of it to clean that mating surface!!!
Old Jan 16, 2006 | 05:18 PM
Not an issue on a '92. The shaft is keyed.
Old Jan 16, 2006 | 05:55 PM
our fuelpump rebuilder said itll go through that key like a piece of paper. Hes seen it a hundred times... hes an anciet guy who has done nothing but rebuild cummins fuel pumps all his life...
actually he sugested to a person here doing a p7100 conversion to a 2001 that he dont use the key, and just make sure the mating surface is extra clean, s it doesnt screw Edit up when it does shear the key and crack a gear...
Old Jan 16, 2006 | 11:45 PM
Smkndzl's Avatar
best thing for cleaning is contact cleaner , leaves no film on the shaft or gear. the worst thing is brake cleaner
sparky10
Aug 23, 2007 09:04 AM
93' Shorty
May 31, 2007 08:30 PM
k9judge188
Feb 9, 2006 07:42 PM
georgemgeorge
18
Jul 1, 2005 08:05 PM
