Old Jul 6, 2018 | 11:56 AM
  #6586
Shelby/Dakota's Avatar
5 Year Member
Tman, any reason why you haven't just ordered one of the custom Brass Tipped plungers? They are considerably cheaper and seem to good to go.
Speaking of I should order one just to have.
Old Jul 6, 2018 | 12:54 PM
  #6587
Where do you purchase? I could get it, and use this bad one as a backup
Btw, Bosch F002D13640 is printed on the Cummins solenoid. This thing better last...
Attached Thumbnails What did you do to your Gen 1 today?-0706181350_hdr-768x1365.jpg   What did you do to your Gen 1 today?-0706181350a_hdr-1024x576.jpg
Old Jul 6, 2018 | 03:06 PM
  #6588
Bob L's Avatar
Tman,
Is that the Cummins Part No. on the side of the box ? (3903575)
I assume it is, just want to make sure.
Thanks for posting the Bosch No.
Can’t believe the price $228.41 WOW ! You’re right It Better Last !
Old Jul 6, 2018 | 03:19 PM
  #6589
Bob L's Avatar
Originally Posted by Bob L
Tman,
Sorry Tman,
I went back and read your post again, you already answered my question.
My oversight.
Thanks for the helpful information.
Still can’t get over the cost. WOW !
Old Jul 6, 2018 | 03:41 PM
  #6590
Sorry Tman,
My oversight.
When you consider I've been,through 3 @ $45 from eBay, how much have I really spent in time, breakdowns, and cussing on the side of the road?
Old Jul 6, 2018 | 04:22 PM
  #6591
Bob L's Avatar
Well,,,When you put it that way
I see your RATIONALE !
Like you say, for that kind of money, it better last a long while !
Old Jul 6, 2018 | 05:25 PM
  #6592
edwinsmith's Avatar
Bla!
For that price it had better outlast the rest of the truck!
Old Jul 6, 2018 | 09:58 PM
  #6593
Jim Lane's Avatar
Cool specialty wrench
Old Jul 7, 2018 | 01:24 AM
  #6594
Tailgate stopped opening last week, the latch on the drivers side was not moving so assumed a clip had failed. Picked up a box of the assorted generic door latch clips and finally got around to checking this evening. Turned out it was the clip at the handle had broken. Had problems getting those phillips button head bolts out...so replaced them with a standard bolt on the re-assembly, might pick up some stainless allen button head bolts one day. Replaced the broken clip and all is well again.
I also picked up 40 bundles of shingles for the shop roof today....loader wouldn't let me take all 61 since I would have been over weight....not that I minded at all, better safe then sorry and I'm sure it's their company policy anyway and I wasn't going to argue. Truck barely felt the weight in the back, springs were just resting on the overloads. Will head back tomorrow and grab the rest.
Old Jul 7, 2018 | 05:35 AM
  #6595
Eh, the guys here would have put that full pallet in your Prius
Old Jul 7, 2018 | 05:43 AM
  #6596
Last night, I took the wife and my 16 year old pirate back to the veterinarian to get her stiches out.
All that " funny sound, funny feeling, truck not quite right.....its all gone, and back to normal.
I guess that little piece of rubber from the fss was blocking the orifice and defueling the motor.
That new, Cummins Bosch Fss better last.....otherwise ill bring the pirate up to the Cummins dealer, and let her loose
Attached Thumbnails What did you do to your Gen 1 today?-0623181236-1024x576.jpg   What did you do to your Gen 1 today?-0622181933_hdr-1024x576.jpg   What did you do to your Gen 1 today?-0706182042b_hdr-1024x576.jpg
Old Jul 7, 2018 | 10:35 AM
  #6597
MrFusion's Avatar
If it fails again put on a pull cable. My only issue with the pull cable is that it makes an already easily stealable truck a little easier to steal.
Old Jul 7, 2018 | 10:53 AM
  #6598
edwinsmith's Avatar
You could use a wheel boot.
Old Jul 9, 2018 | 05:51 AM
  #6599
Angry Johnny's Avatar
You could always adapt a removable steering wheel.
Old Jul 9, 2018 | 07:08 AM
  #6600
The other day, when I replaced my FSS, I also replaced the wire ends to the KSB, and the FSS itself. They were all loose, and years had paid their toll on them. Time for new connections.
Also, cleaned out the remaining bits of rubber that fell off in the pump from the FSS plunger going bad. With the FSS out, you pump the manual lever on the lift pump, and it pushes all the gunk out of the pump itself, out into the open through the FSS hole. I used my Vac-u-brake to suck it all out, while pumping. Then I wiped out the hole with q-tips ensuring nothing left behind. A dab of never seize on the threads, replaced the wire ends, and it's been running (and shutting off) like its supposed to.
A few years ago, I pulled the bracket for the throttle assembly where the cables all route through. The bracket itself isn't an issue, but the pivot itself had come loose over the years as it's only press fit together. I tried, back then, to re-press the fittings, but they just came loose again. Not a HUGE amount of play, but enough to retard response with the pedal, as instead of moving in a straight line, the pivot was articulating sideways, albeit minutely. Welded it up and it's rock solid.
No more loosey goosey at the throttle arm pivot
Attached Thumbnails What did you do to your Gen 1 today?-0706181402_hdr.jpg   What did you do to your Gen 1 today?-0706181402b_hdr.jpg   What did you do to your Gen 1 today?-0706181424_hdr.jpg   What did you do to your Gen 1 today?-0706181434_hdr.jpg   What did you do to your Gen 1 today?-0706181444a_hdr.jpg
What did you do to your Gen 1 today?-0706181508a_hdr.jpg   What did you do to your Gen 1 today?-0706181533a_hdr.jpg   What did you do to your Gen 1 today?-0706181607_hdr.jpg   What did you do to your Gen 1 today?-0706181644_hdr.jpg   What did you do to your Gen 1 today?-0706181715_burst01.jpg
