turbo housing
Would it be safe to run a 14 cm non wastegated with bosch 190s? I know a guy whose got the Banks kit and doesnt have his waste gate hooked up with 190s and he pushes 28-30 psi? I just dont want to blow the head gasket out of my truck cause I cant afford it.
Tow rig or play truck? For a play truck I'd be real tempted to run the 12 cm wastegated, with some porting and a drilled divider of course. On a working truck I'd want the freer breathing of the 16 cm.
I'm running a waste gated 14 that I've temporarily pinched off the reference hose because I can't get a working controller figured out (I've gotten sidetracked again
) . . . . . . Dave?Running what you see in my Sig, at WOT, I'm right at 38psig boost.
But I've also got the fuel screw to the point I won't go above 1250*F with an extended full throttle run, and no load (play truck).
Check out THIS thread . . .
I can't believe it has been two years since this was a hot topic . . . dang! I guess I've been virtually associating with you all for a while now. (It's good for me, but you all should be worried!
Originally Posted by BC847
IMO, yes.
) . . . . . . Dave?
http://cgi.ebay.com/ebaymotors/Unive...QQcmdZViewItem
This is the one I'm running. It runs me right up to 40 psi and holds it until the truck defuels (or I do).
Thanks big guy.
I don't care what those women said, you're alright.
ajbirken
Sep 6, 2006 12:11 AM
95black2615
Jul 21, 2005 09:06 PM
j
Jan 9, 2004 08:19 AM
HOHN
Dec 7, 2003 02:07 PM
