turbo housing
Old Dec 15, 2005 | 08:39 PM
DODGE 92's Avatar
turbo housing
another dumb question those the 18.5 housing bolt on at the same place as the 21 cause maybe i can get one for free
Old Dec 15, 2005 | 08:54 PM
G1625S's Avatar
Yup, it sure does Go for it, ANYTHING is better than the lagmaster 21!
Old Dec 15, 2005 | 08:55 PM
spunbearing's Avatar
Yep but while you're at it might as well go to a 16.
Old Dec 15, 2005 | 08:56 PM
G1625S's Avatar
yeah, but the 18.5 is priced right
Old Dec 15, 2005 | 09:07 PM
Underpsi's Avatar
i'd say go for it. I hardley noticed a difference when i changed my 18.5 to a 16 so it seemed more like a waste of money. I think it could have been put somewhere else more hp efficently
Old Dec 16, 2005 | 03:49 AM
bgilbert's Avatar
Yep free is good. If you can get a 18.5 for free, that would be worth the install to switch from the 21 to 18 in my opinion. 16 is a money maker for diesel vendors.
Old Dec 16, 2005 | 01:48 PM
Free is definately a good price. I'm running a wastegated 12cm right now with the wastegate not connected. Got it for $50. It's snappy off the line but pretty flat up top. I live dangerously. I have my fuel cranked way up and no guages. Dohhhhhhhhhhh Still running stock injectors though so no melt down so far. I need to pull my head out and get some guages on this thing before I play too much more.
Old Dec 17, 2005 | 08:42 AM
lovemysan's Avatar
0-70 I can hit 1250 on the pyro. Stock injectors and tired lift pump. 2-3 seconds later its in critical temp zone. It really heats up quickly you'd be surprised how fast it actually happens. I'd say 0-100 and I'd be 1400+ and climbing, but I don't drive that fast.
Old Dec 17, 2005 | 10:24 AM
mhuppertz's Avatar
I disagree about the 16cm. I went from an 18.5 to the 16 and my truck came alive. The air is much thinner up here though, and that could make a difference...
Old Dec 17, 2005 | 01:46 PM
Holsteinman's Avatar
I have noticed that more than not, people that say going from an 18.5 to 16 did not make much differene have auto tranny's. The one's that say it helped quite a bit have manual tranny's.
Old Dec 18, 2005 | 12:53 AM
Underpsi's Avatar
I have a manual tranny and i didn't feel a big difference. I didn't have a boost gauge at the time I put it in so im not sure of how much of a difference it actually makes as far as boost/spool up.
Old Dec 18, 2005 | 10:53 AM
mhuppertz's Avatar
Mine went from a 15psi slug to a 30psi monster.
Old Dec 18, 2005 | 11:33 AM
Dusty Ratcliff's Avatar
My old 90' was a beast down low with a 12cm & the wastegate blocked off, should be able to find one really cheap if not free, in fact I think I have 3 or 4 of them laying around here, I liked it much better, but I done alot of towing & the bottom end power was a little more important, so I guess it depends on what you're gonna do with it, but I was very pleased w/the 12cm on mine, Dusty
Old Dec 18, 2005 | 11:46 AM
bgilbert's Avatar
You must of done more to it than just change housings. 18.5cm to 16cm housing, boost gained is 2.5psi. For every drop in size equals 1psi of boost. You must of had a charge air leak prior to housing change. Then when you put it back together, charge air elbow/hump hoses etc, you got it tight.
Old Dec 18, 2005 | 01:57 PM
If that's true I'm living more dangerously than I thought. When we hooked up a temporary boost guage to my truck after doing my pump rebuild and mods I was hitting 25 psi boost with my 18.5 housing. With my 12 I must be dangerously close to a head gasket failure. Time for guages. I kinda went about this thing backwards.
