Stock Injectors on a '92
How much power can you get out of them by turning up the pump? I did try searching and I couldn't find an answer to this question.
My goal is 250-300 bhp for the time being. Bombing on a budget.
How about for a non-I/C truck? What do you think I can get from my stock injectors with a BHAF, 4" exhaust, 16cm turbo housing, 60mm wheel, 3" crossover, piston pump, DennyT Stage2 pin, etc.?
For some numbers close to what your looking for I dynoed here while back with this:
Fuel screw maxed
Afc adjusted
stock injectors
4" turbo back
hx35/12cm
3200 GSK
DennyT Stage II
stock timing
stock injectors
NV4500
235hp 582tq
Thats a high mileage motor on a VERY sad and tired lift pump.......you would see higher numbers with your setup....
Fuel screw maxed
Afc adjusted
stock injectors
4" turbo back
hx35/12cm
3200 GSK
DennyT Stage II
stock timing
stock injectors
NV4500
235hp 582tq
My truck made 346hp/758tq with stock n/ic injectors. 366 gov spring,fuel screw maxed,afc foot ground,timing bumped,piston lift pump,1stgen intercooler,hx-35 with 16cm housing,
What is the compressor side difference between a stock '92 turbo and an HX-35?
I'm thinking about upgrading my compressor to one from Gillette Diesel.. (GDS CH-04)
Is there any danger or negative effects to making so much power with stock injectors?
jgiachino
05-12-2008 02:06 AM
sammy340
04-05-2005 03:55 PM
