Lift pump
I'm not sure what part of "it's not a High Volume Lift Pump" as stated by Nascar Mark is hard to understand.
So you know, your getting some bad info here. 3936320 Fuel pump (new number 4988751) is NOT a HVLP pump
Well, if that's indeed true, someone better change the sticky, because Thats where the numbers come from
https://www.dieseltruckresource.com/...22/#post915409
Then the pump number changed in 2007 to this
https://www.dieseltruckresource.com/...3/#post1471359
Then the pump number changed again in 2008 to the 4988751
https://www.dieseltruckresource.com/...3/#post2236558
Then BC updated the information here for guys who are running big power, vs a stocker replacement to the piston lift pump:
https://www.dieseltruckresource.com/...t-pump-176472/
Lots of as you say "bad info" that probably a couple hundred guys have done before, and none of them care to update it ?
BC847's thread
BC847's thread
1st Generation Admin
Folks, that thread I wrote over eleven years ago revolves around a low-pressure/low-volume piston lift-pump. While I did not specify clearly what I was working with in that thread, I certainly never said nor implied it's a high-volume/low-pressure lift-pump.
As mentioned above, some months later, I posted a thread where I found that the 2nd gen piston-pumps ran a larger bore thus, a higher volume. In that thread I included a picture of the two pumps side by side with the springs (I believe it was during this time, some folks started thinking about swapping springs to come up with a HVLP pump. ).
The part numbers shown throughout my thread are for a low volume/low pressure piston pump. I think it's normally used in a agricultural application.
The following 2 users liked this post by BC847:
edwinsmith (12-30-2018),
NJTman (12-30-2018)
Received 1,637 Likes
The benefit to these forums, besides having to read unneceasary, detracting comments such as Ofelas declaration above, are that the folks who try to help others with their quests, can inevitably learn something new in the process.
So indeed the OP can have a more reliable pump, as his original intent was, but it won't have the benefits of being a HVLP unit.
Might be beneficial to alter the sticky thread , clarifying the pump is a simple piston pump, of low volume, low pressure, so that misunderstandings can be minimized in the future.
My apologies to the OP for providing information that wasn't entirely correct.
Yukon Dodge
18
07-01-2004 10:08 AM
Puke
05-22-2003 12:18 AM
Haulin_in_Dixie
47
11-17-2002 09:30 PM
