lift pump a lift pump?
Old May 19, 2005 | 04:46 PM
Txwelder's Avatar
Is a 5.9 12 valve lift pump the same for every application? The Case/IH dealer has lift pumps for $105 but they said they dont know if it will apply to Dodge as they use the 5.9 in tractors. Can I buy this pump and have good use of it? Thanks in advance.
Old May 19, 2005 | 06:00 PM
kd460's Avatar
Yes and no. You need to bring in your pump in with you. I have read that the lift pump is a direct swap. I have also read that you have to change the inlet (or outlet) for the fuel line on some of the pumps, and yes, the case/IH uses the cummins b in several applications.
I will try to dig out some part numbers and info for you this eve, hopefully others will chime in with some info as well.
Kevin
Old May 19, 2005 | 06:10 PM
kd460's Avatar
http://turbodieselregister.com/forum...3&page=1&pp=15
http://turbodieselregister.com/forum...ight=lift+pump
http://www.dodgeram.org/tech/dsl/fuelpump/replace.htm
Hope it helps, Kevin
Txwelder
Nov 26, 2025 01:53 AM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
cheng
Jun 22, 2004 12:01 PM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
