Crewcab update...
Old Feb 7, 2014 | 02:18 AM
  #511
Washer goes between pulley, and fan clutch nut.
And lots of clearance now....
Old Feb 7, 2014 | 02:25 AM
  #512
Thought I had a fix for the E-brake system. The axle cables from the 93 are a lot longer then the 84 cables....where they come through the bracket on the driver side.
I swapped over the 93 clubcab e-brake assembly and main cable, but was still about 14" short. So I thought I would just add an extension to the threaded end of the E-brake cable.
I got some ready-rod, and a couple threaded couplers that I welded together. Viola I thought I had it!
Turns out that the axle cables don't pull the same length. So the bracket twists and bent the ready-rod.
Guess I'll be swapping the E-brake cables from the 84 Dana 60 over the 93 Dana 70.
Old Feb 7, 2014 | 02:39 AM
  #513
I also ran into an issue with the flex line from the rear axle, up to the frame. Originally the flex line ran up to the bracket with the female threaded end pointing towards the front of the truck. But with the RWAL valve, this required the brake line to do a tight 180* turn.
So to make things easier I had decided to install the flex line pointing towards the back of the truck. Thus eliminating the 180* brake line bend. But what happened with this is that once the fuel tank was installed it was hitting the flex line.
I had been thinking about how to fix this, without bending new lines. I finally was able to find a short 90* brake line fitting...or should I say a Tee...with a plug.
Then I bent a spare bracket I had 90* so that the flex line would now be coming straight up.
And installed...
The only thing I'd change is the tee. If the male tube flare had been in the center port of the tee, then it would have been easier to get the brake line lined up. And not have had to crank the begeezis out of the fitting I used to get it to line up.
Hopefully I don't have any leaks.
Old Feb 7, 2014 | 05:44 AM
  #514
bannerd's Avatar
Cardone joint is a PITA! Did you figure out the sping and cup retainer? Mine kept pushing the seal out and I ended up welding the seal right to the cup.
Old Feb 7, 2014 | 09:25 AM
  #515
Dieselbuilder's Avatar
You may find the fan is still to close to the dampener as it doe's flex back when running you might want to go electric fans just a thought?
Old Feb 7, 2014 | 10:21 AM
  #516
No they did it for me at no extra charge....I was more then willing to let them...
Thanks for the advice.
I did remember that the fan does flex under load. There is about 1/8" to 3/8" clearance now. I pulled on the fan blades to see how much "flex" I could get....as of right now it does not appear that it will hit.
But that does not mean that under high heat, and massive load situation it will be different. If that happens then electric fans might be in the future.
Old Feb 19, 2014 | 08:18 AM
  #517
mknittle's Avatar
Man it's the little stuff that takes the most time. You are getting there though
Old Mar 1, 2014 | 01:47 AM
  #518
Firewall repairs
I know I have not been updating regularly...trying to get the crewcab done ASAP. I'm starting to jones hard on not driving my cummins.....
I will try and update a bit over the next week or so...when I find time.
I stripped out the firewall and got the dash out of the truck...without having to pull the windshield...Woohooo!!
And you can see some of the butcher job they did installing the clutch bracket, and the hole in the firewall.....
Old Mar 1, 2014 | 01:51 AM
  #519
So since I couldn't live with the butcher job, I decided to weld in some patches and then I could redo it properly.
I made up a one piece patch and welded it in.
But after some measuring I noticed I needed a bit more material on one side. So welded in another patch.
Now I needed to mark out the new hole. Little thinking outside the box got me what I needed.
Old Mar 1, 2014 | 01:58 AM
  #520
Used a couple different size flapper discs on the die grinder to slowly open up the hole.
And then a little rat file work on the wiring bulkhead area to get it into shape. All done and ready for paint.
And all painted up...
Just a rattle can paint job...but much happier now that the firewall is repaired, and painted.
Old Mar 1, 2014 | 06:53 AM
  #521
Wow !
You've come a long way, and the thousands of small tasks required to do so. Not as easy as I thought it would have been. Awesome job !
How do you have green grass there ? Winter has left brown straw, partially covered in snow and ice in my yard....and I'm a lot further south than you are.
Old Mar 1, 2014 | 08:30 AM
  #522
mknittle's Avatar
Looking Good! I have been watching for an update. yours is one of my favorite builds. We have quite a few first gens and old Dodges around here but I have only seen one crew cab. I used to see one the Air Force had with an ejection seat mounted in the bed facing backwards.
Old Mar 1, 2014 | 09:18 AM
  #523
gyman98's Avatar
Looks great! Where you have the plate covering the mechanical clutch hole, I put the clutch rod rubber boot in there and ran all my extra wiring through. Pyro, boost lines, all that stuff. Sealed with a zip tie after. Just a idea for you if you have any extra stuff in your truck
He lives in a pretty mild area of Canada. Last time I was there in mid winter the bugs were flying an everything was nice and green. I would love to move there! -36 here right now lol
Old Mar 1, 2014 | 09:47 AM
  #524
Originally Posted by NJTman
Wow !
Appreciate the kind words! And yes it's always the little things, and details, that end up taking the most time. And living on the "Wet" coast of Canada has a few perks...
That would be a thing to see....even funnier having someone strapped into the thing...even if it didn't work....just funny to think that it "might"...
Thanks for the kind words!
That might be a good solution to my extra wiring issues. Never thought of using the manual clutch hole, with a new boot. Thanks for the heads up on that!!
Old Mar 1, 2014 | 10:01 AM
  #525
Like Gyman98 did, I ran boost, pyro and other lines through my old clutch pedal boot in the fire wall after my swap.
That is a clean looking firewall now, after fixing the butch job!
