Click click click click
Old Aug 14, 2007 | 10:42 PM
marksmith's Avatar
Yup. Click click click coming from the drivers front wheel area. Follows wheel speed. Goes away if I put a little pressure on the brakes.
First thought it was an axle joint, but it doesn't wiggle and appears well greased. Then I took the ring that engages when you lock in hubs (dont know what it is called) out and greased the heck out of the insides.
Still has the clicking.
While I had the front tire off the ground I wiggled and pulled and spun.... no clicking (this was AFTER the greasing of the hub) The tire stays rock solid. No play anywhere I can find.
Anyone have a clue what this might be?
Thanks
Mark
PS. Its a 93 LE auto 4x4
Old Aug 14, 2007 | 10:49 PM
rbrettctd's Avatar
I had that with a slightly bent dust shield. Took forever to figure it out. give it a look.
Old Aug 14, 2007 | 10:50 PM
Dodge359's Avatar
Sounds like the brake pads are slipping back and forth in the caliper. My snowplow does the same thing. They make a "membrane" that can be applied to the piston and it kinda sticks to the back of the brake pad and retracts it when the piston retracts.
Old Aug 14, 2007 | 10:52 PM
Dodge359's Avatar
I dont know if the 93s have the clip that hooks to the pad and the piston. If so that might be loose or broken.
Old Aug 14, 2007 | 10:54 PM
marksmith's Avatar
Now THAT is the reason I love this place!
I will take a look at o'daylight 30. This is driving me NUTS.
Old Aug 15, 2007 | 12:29 AM
jjdiesel1990's Avatar
that's what mine is doing. where can i get this membrane?
Old Aug 15, 2007 | 07:53 AM
Dodge359's Avatar
It used to come with the pads I bought at NAPA but they will probably have it separate there too.
Old Aug 15, 2007 | 03:22 PM
thanks man
Old Aug 16, 2007 | 09:11 AM
timb's Avatar
Clicky,Clicky,Clicky. Theres a bomb under the hood ready to go off. All you can do to stop it is to get out the check book and buy a set of DDP stage 4's, An HTT 62/13, o-rings and head studs. Then the Clicky, Clicky will quiet down a little.
Old Aug 16, 2007 | 09:03 PM
marksmith's Avatar
LOL
FIRST.... Three piece manifold. Mine seems to have shrunk.
THEN.... Build me a tranny that doesn't slip to the moon.
MAYBE.... Some stacks, turbo, fuel....
Old Aug 16, 2007 | 09:08 PM
MikeThomas's Avatar
Hehe, have you looked for a nail in the tire yet? Just because its not leaking down doesn't mean its not there.
Old Aug 16, 2007 | 09:39 PM
marksmith's Avatar
Yup! Even swapped front for rear to see if the problem followed.
This does it on gravel... pavement... grass..... you name it.
Old Aug 16, 2007 | 09:54 PM
SuperiorRam's Avatar
it's shot i'll give ya a grand for it
no no no just jerkin around you'll get er
good luck
Old Aug 16, 2007 | 10:45 PM
marksmith's Avatar
LMAO!!! I haven't had this truck for 1 month yet! This is what she looked like after I yanked the running boards, the factory steelies (with caps/rings) and tossed on some of my uncles 'spare' tires.
I dont think she'll go anywhere. Gave 7200 for her. Really clean IMHO (factory EVERYTHING in cab and it all works) LOADED LE. (first tranny cooler I have ever seen factory that was under the bed)
There is only a few quirks she has that I need to fix for my sanity.
Looks like it will be Sunday before I can have a look @ the brakes. HOPEFULLY it will be simple.
Thanks again
Mark
Old Aug 17, 2007 | 02:57 AM
MikeThomas's Avatar
Sharp..............!
ldornak
Jul 4, 2009 06:15 PM
Sleigher
Mar 23, 2007 12:23 PM
cheapskate
19
Dec 27, 2006 08:05 PM
PaulDaisy
Dec 2, 2006 12:36 PM
bnold
Apr 25, 2006 06:57 PM
