What's the best mileage box/programmer for 01/02?
Old Jan 4, 2009 | 09:35 AM
J-man's Avatar
A friend of mine has an 01 or 02 ho and wants a mileage box or programmer. He is not interested in power and doesn't want to have to install gauges. What would be the best for mileage, and what would be the best for budget?
Old Jan 4, 2009 | 12:33 PM
sheriffav8r's Avatar
1. Buy gauges anyway. 2. Hawk gauges while driving. 3. Look into a programmer....
Old Jan 4, 2009 | 12:59 PM
Moules's Avatar
TS MVP, i dont own one but i have read and heard from a couple of people that they have noticed quite a difference in fuel mileage. i am looking into one myself for daily driving.
Old Jan 4, 2009 | 01:54 PM
Fern's Avatar
You can find a used Edge EZ for pretty cheap.
Old Jan 4, 2009 | 02:45 PM
Crazydave's Avatar
x2 easy and inexpensive to find a used one i had a nice mileage bump when i put an EZ and rv275's in
Old Jan 4, 2009 | 05:19 PM
J-man's Avatar
Thanks for the info, guys. Any more ideas out there?
Old Jan 4, 2009 | 11:41 PM
J-man's Avatar
Any suggestions other than the EZ, or is that going to be his best bet? It is and 02 by the way.
Old Jan 5, 2009 | 01:01 AM
Flatbed24v's Avatar
gauges are very very important even on a stock truck. Gauges should be a fuel pressure, boost, pyro, and if it's an auto get a tranny temp. A fuel system upgrade is in order even in stock form as well. If he doesn't want to address this problem then he should start saving for a new vp44. I would add anything without these upgrades. Once these are addressed then I would get edge comp or edge juice with attitude(this comes with gauges) or quad adrenaline with pulse( this also comes with gauges). These are all adjustable on the fly so you can do some tuning to get the most out of it. His mpg will be determined by the way he drives so having a box that has a wider range will help to find his sweet spot. The comp set on 2x4( I think) would be the same as edge ez. So by getting the comp you get the ez plus having more options as well for tuning. Just because the box as all out power does not mean he has to use it. Just my $.02
Old Jan 5, 2009 | 06:06 AM
smokinram99's Avatar
i have an EDGE EZ by 1 year now. when I bought the truck it stays at 15 16mpg; w the EZ I have never seen 16mpg again on my truck! i'm around 19mpg now, highway/city...It's a great module, it adds only 60hp, don't worry if you have a stock truck, but you feel the difference in your gas pedal.
i also raccomend a fuel pressure gauge, you can take a look at your fp and be safe on your VP44
rob
Old Jan 5, 2009 | 07:02 AM
Danderson's Avatar
Ditto x3
Ditto x3. An Ez alone will help and add 275's to it and you've scored an economical 100 hp w/better fuel economy. FP and at least an EGT gauge is a must.
Old Jan 6, 2009 | 09:10 PM
J-man's Avatar
So injectors can help mileage?
Old Jan 6, 2009 | 09:44 PM
Flatbed24v's Avatar
yes if you can keep your foot from enjoying the new found power
RCOaks58
19
Mar 15, 2010 01:34 PM
Bigolemegacab
Sep 27, 2007 09:44 AM
cowboy717
Aug 25, 2006 01:35 PM
bigman
16
Aug 25, 2006 07:00 AM
G-NOTE
13
Aug 16, 2005 02:03 PM
