Best fuel box or programmer for a 99...
Old Aug 21, 2006 | 11:07 PM
bigman's Avatar
Hey fellas, been away from second gens for awhile now. My last one was a 2001 and 6 speed with the edge ez. Anyway a good friend of mine just picked up a mint 99 auto quad cab 4x4 24 valve and i was wondering what was the preferred method for adding a little extra fuel was these days. Not looking for something as gnarley as the smarty, maybe something more in the way of a programmer that adds and extra 50-60hp. Thanks!
Old Aug 21, 2006 | 11:26 PM
Ph4tty's Avatar
But the smarty is a programmer that adds 60+ hp =P
And I beleive it is also the preferred method
Old Aug 22, 2006 | 06:04 AM
crobtex's Avatar
EZ and RV275's has made a lot of difference in my '99. Last dyno = 304 hp, 718 on the torque and avg 19 mpg + overall.
Old Aug 22, 2006 | 06:54 AM
blackdiesel's Avatar
Registered
what Ph4tty said, and you can read and clear codes and update it from the internet and it adds more drivablety than and ez (more low end) = more FUN
Old Aug 22, 2006 | 01:18 PM
daniel's Avatar
where can you buy the rv275s and how much do they usually run. ive been thinking bout a set of injectors for my 01 HO
Old Aug 22, 2006 | 02:26 PM
Registered
Dad got a set of bosch 300's for $300 off e-bay
Old Aug 22, 2006 | 02:37 PM
displacedtexan's Avatar
THe RV275s and the 300 are the same injectors, right? I seem to remember that some vendors just call them 300 because it sounds like theirs are better than the ones the other guy has...
Old Aug 22, 2006 | 02:40 PM
RJF's Avatar
RJF
Yes, 300's are the same as 275's. I wouldn't use them though as they aren't that great.
I'd use a Smarty or an EZ.
Old Aug 22, 2006 | 05:10 PM
daniel's Avatar
well what injectors would be good with the ez.
oh yeah an im for the ez
Old Aug 22, 2006 | 05:21 PM
Tiny's Avatar
Get the Edge Comp, tap the wire when you are ready. For injectors I would get a set of Mach 1.6s from Don Morrison, www.f1diesel.com. HTH.
Old Aug 22, 2006 | 06:50 PM
RJF's Avatar
RJF
Mach 1 injectors are really good for mileage.
Old Aug 22, 2006 | 06:53 PM
crobtex's Avatar
There are a lot of ways to go, I just happen to like my setup for my needs.
Old Aug 23, 2006 | 10:27 AM
jriggs_18's Avatar
I would recommend the Juice with Attitude, its a few more horse then you would like, but I has alot of features with it, its not too expensive either.
Old Aug 23, 2006 | 12:31 PM
RowJ's Avatar
Originally Posted by bigman
.. Not looking for something as gnarley as the smarty, maybe something more in the way of a programmer that adds and extra 50-60hp. Thanks!
Smarty is A-1..... but it's hard to pass up the EZ when they are selling for such great prices in the Classified Section.
Still a great starter kit!
And with 275 injectors, you get great mileage bump, as long as your not going to want more later.
May, however, over tax the tranny?
RJ
Old Aug 25, 2006 | 03:44 AM
ib516's Avatar
I have an 02 auto/3.55 truck that I use to pull a 33', 9000# RV with. I run an Edge EZ, and am thinking about adding 275s. I currently peak at 1350* on long hills, and usually run 1000 - 1100* pulling on the flats. How much will adding 275s raise my EGTs? Will they make towing impossible due to too high EGTs?
