smarty and 100horse injectors
Old 06-17-2007, 04:52 PM
my_samurai's Avatar
i used to have a edge EZ with 100 horse injectors on a stock turob. i thought this setup would go pretty good. well i sold the edge and im looking at the smarty for my next box, my ? here is how would that be compared to the EZ with the injectors?..would it be a big deffernce in power? would it be worth the money to do a smarty over an edge comp?
Old 06-17-2007, 04:57 PM
Ground Shaker's Avatar
The smarty love injectors upgrades. I put my one truck back to stock and played around with it to feel a difference, once I put a set of injectors in it it really brought it to life. I was suprised how well it worked.
Old 06-17-2007, 05:10 PM
Danderson's Avatar
Smarty
My '99 was equipped w/mach 1.6 injectors(90hp) and an EZ. I borrowed a Smarty from Bob Wagner. The difference was night and day on the low end. With my BHAF and stock turbo you had to watch the go peddle as smoke was an issue. The vehicle fuels so much lower in the rpm level,it takes a few seconds for everything to level out. It just a learning curve to minimize the smoke. I did have a DTT auto which is necessary w/injectors or a beefed up clutch. Bob used to have loaners out there. Try before you buy. Even new ones come with a buy back guarantee.
Old 06-17-2007, 05:42 PM
my_samurai's Avatar
was the power better over all better with the smarty than the EZ ground shaker?. i do wish there was one near that i could try, but im getting alot of info on the smarty from doing ALOT of research. im not in the game to make big HP #'s ive had my trans built to hold the power, but i dont want to tear up 2k of upgrades in my trans anytime soon..Im a lil bit scared to do a comp with the wire tap.
Old 06-17-2007, 06:54 PM
displacedtexan's Avatar
If you don't want all out power, and don't wanna tap the wire, I wouldn't see any reason to go with a Comp over a Smarty, the Smarty would give you the same overall power, everyone that has one loves the driveablity, and is a code reader.
Old 06-17-2007, 07:28 PM
HOHN's Avatar
Peak power (the "number") will be about the same on a Smarty as an EZ. But the Smarty is a lot more responsive on the bottom end-- the truck will actually MOVE-- not just make smoke-- when you get on it.
I've had the EZ and now have a Smarty. I much prefer the latter. The only way to add more power than a Smarty is to tap the wire.
JMO
Old 06-17-2007, 07:37 PM
my_samurai's Avatar
sounds like a winner to me HOHN thank for the info
Old 06-17-2007, 07:45 PM
JDGnut's Avatar
Post your location.. I'm sure there is a member in your area that will let you try a Smarty.. Its only a few mins to change the program from truck to truck..
Bryan
Old 06-17-2007, 07:58 PM
my_samurai's Avatar
Yeah anyone in the my area
stock03
34
04-21-2011 07:40 AM
vj_M
07-29-2008 10:15 PM
KRB
05-20-2007 06:20 PM
bnold
39
06-04-2006 08:21 AM
BIGOKIE
07-21-2004 05:53 PM
Quick Reply: smarty and 100horse injectors
