truck won't turn over
Old Jun 1, 2004 | 07:58 AM
grapes43's Avatar
My 92 will not start. I turn the key on, the glow plugs cycle, then I try to start it. A load metalic click can be heard from the fender well and that is it. I tested the starter. It works and is putting of 200 amps, which is high. Please advise.
Old Jun 1, 2004 | 10:15 AM
BIG&BAD's Avatar
check out this tread https://www.dieseltruckresource.com/...threadid=44972
it should give you some help as were to start
Old Jun 1, 2004 | 10:16 AM
Smokee's Avatar
Did you try shorting across the starter?
Old Jun 1, 2004 | 01:55 PM
Haulin_in_Dixie's Avatar
I would verify that the engine will turn over manually.
Old Jun 1, 2004 | 06:03 PM
wgingg's Avatar
like haulin said turn it over by hand if you can. ive had a cat motor do that and it was the cylinder liners corroded and coolant seeped in.
Old Jun 1, 2004 | 07:36 PM
thumper 549's Avatar
glow plugs?????????????????????/
Old Jun 1, 2004 | 08:02 PM
jaconst's Avatar
what about your starter contacts or is that just a 2nd gen probalem? you need to change the contacts in the selenoid I believe
Old Jun 2, 2004 | 09:30 AM
grapes43's Avatar
thanks for the info. The power cable that ran to the starter was terribly corroded down inside the insulation out of sight. The terminals were corrosion free. Cleaned it up and fired it up.
Shanajustin
Apr 28, 2017 12:14 PM
drakeslayer
Dec 15, 2011 08:28 AM
drakeslayer
Dec 15, 2011 12:26 AM
Remnik
Aug 7, 2007 02:21 PM
S_Wilson
Jan 24, 2005 06:54 PM
