Truck won't turn over
Old Jan 23, 2005 | 03:55 PM
S_Wilson's Avatar
I went out to start my '02 this morning and it wouldn't turn over. all the gauges or acting normal
I checked all the fuses and couldn't find anything wrong. batteries seemed to be charged. I drove all day yesterday without any problems. Any Ideas?
Old Jan 23, 2005 | 04:15 PM
crobtex's Avatar
Did you check the voltage on the batteries? When mine went bad, it started one day and not the next. How about the starter...wirs, etc?
Can you hear the LP run when you turn the key on?
Old Jan 23, 2005 | 05:20 PM
S_Wilson's Avatar
replaced the batteries(with ones i had, But I know are good), no good. checked the starter wiring everything looks good, banged on it with a hammer for good measure. still nothing. dunno about the LP (lift pump?) I can can hear humming for a second or two when i turn the key on. This is my first diesel and i've only had it for three months so I'm still learning. It only has 46000 miles on it. Are the starters prone to going haywire on Cummin's?
Old Jan 23, 2005 | 05:43 PM
crobtex's Avatar
The humming is the LP priming.
Standard or auto? You might check the clutch position switch if it's a standard.
I don't know. At least it's still in warrenty.
Old Jan 24, 2005 | 06:54 PM
S_Wilson's Avatar
Had it towed to the dealer this morning, come to find out there is a anti-thieft chip installed thats lets you pull the chip so the truck won't crank. It was installed by the dealer where I bought the truck. It shorted out.
Shanajustin
Apr 28, 2017 12:14 PM
drakeslayer
Dec 15, 2011 08:28 AM
drakeslayer
Dec 15, 2011 12:26 AM
Remnik
Aug 7, 2007 02:21 PM
grapes43
Jun 2, 2004 09:30 AM
