Truck won't turn over.
Old Dec 14, 2011 | 03:31 PM
drakeslayer's Avatar
I drove my truck home approximately 3 miles sunday and parked it. This morning it won't even try to turn over. The check engine light comes on, then flashes 10 times and stays on. It is leaking a small amount of fuel. I'm going to check the filter cap seal and relace it plus unhook the batteries for 1/2 hour just to try that. It is a 2006 5.9 liter with 55,000 miles. Any help would be greatly appreciated. I have ried to retrieve codes by cycling the key on,off,on,off,on but cannot get it to work.
greg Damitz, Roseville ,Ca
Old Dec 14, 2011 | 04:34 PM
steelblitzkrieg's Avatar
DTR Detective
Try your other key to make sure it's not the security system. I believe it should still start and run for a few seconds even if it doesn't recognize the key, but my Mustang wouldn't even turn over when it occurred.
Old Dec 14, 2011 | 05:59 PM
After changing the fuel filter to put a new cap seal in it the truck started. Iteither had something to do with the filter, seal or the hood struts letting the hood slam jossled something. So I'm either lucky or a dumbass.
Old Dec 14, 2011 | 06:14 PM
Spooler's Avatar
If the truck didn't even turn over check the driver's side motor mount. You will have a yellow wire with blue tracer that runs real close to it going to the starter, It is the trigger wire. Make sure the mount has not chaffed the wire.
Old Dec 15, 2011 | 08:28 AM
Thanks. I'll take a look at it.
Shanajustin
Apr 28, 2017 12:14 PM
drakeslayer
Dec 15, 2011 12:26 AM
Remnik
Aug 7, 2007 02:21 PM
S_Wilson
Jan 24, 2005 06:54 PM
grapes43
Jun 2, 2004 09:30 AM
